Rover t16 in a dolly
Theres a few been done.I saw a T16 today. Mates putting one in his 1.4 rover 25
Search the Metro forum's for info.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
OK found my way on to this site yes you was right the engine was to high and it was just plonked in there just to see if it will fit now it is in properly its not a easy fit.
im only doing it this way to keep it in the family tree triumph to rover there has been many alterations to get the engine in and then it still needed a "power boulge"
to shut the make do bonnet im posting some more up to date piccies on the other site
Sorry George
but Ive never seen or heard of a factory sold one...
Given that about 80 TR7 Sprints were made and one a month at least on ebay you would think somebody would put an O series MGB on at least once in the 5 years I've tracked ebay.....
Itals and Moronas yes....B's I dont think so but could be wrong...
T16 'box
According to a recent PPC magazine one of the staff is fitting a T16 in an MG. He also rekons, would you believe it, that the crank flange on the T16 is the same as MG B series and also accepts the plate behind flywheel. All you need is B series flywheel, back plate, clutch and gearbox and apparently it all just bolts together. Not sure if this is any help in a dolly tho' !
he is right the blocks have not been changed at all im using lt77 gearbox out of a sherpa 200 and its clutch went with no problems at all but getting it all to sit in the engine bay took a lot of mmmmmmm and cups of tea i have had to lower the sub frame 40mm i will get some piccies of them soon and as the dizzy cap and throttle body are now at the rear of the engine bay i have had to cut the first part of the bulkhead and then build it back up again as i said a lot of hassel just to put a t16 turbo in i bet a cossie lump is easyer but its not in the family tree
Hmmmm
That must mean you could do an L series direct injection turbo diesel dolomite just as easilly then?
Dives for cover...
Dives for cover...
Hello
Top bloke that Mr T16toledo. Dab hand at bypassing a blown heater matrix on Golf GTIs.
Tinweevil
Tinweevil
Heap o' junk
Yep, yours was it's last breakdown on me. It went on ebay within a couple of weeks and fetched about 4 times what I was expecting
The current owner bought it to do the Plymouth Banjul and started preparing it immediately (May). I checked their web site a week ago and they still hadn't managed to get the heater matrix changed. AdamF on this forum is doing the P-B too, I've asked him to wave for me each time he passes it at the side of the road.
Are you still after a decent bonnet? I think I've a good spare still.
[Edit] Just checked again, now fixed. 6 months to change a heater matrix - what a car!
Tinweevil
Tinweevil
