Rover t16 in a dolly
KWM338R
#1 Post by KWM338R »
Couldn't find any info in the archive. Has this conversion ever been done?Will the Sprint gearbox mate upto it relatively easily and handle the power, about 200hp aren't they? Unfortunately I live 3000+ miles from the nearest t16 so it's all daydreaming right now. was reminising about me mums old rover vitesse, was a lot of fun in my younger days!
Lewis
#2 Post by Lewis »
Someone's fitted a K series to an L-series (can't remember, may be an LT77? One out of a Sherpa, IIRC) box, in a two door Toledo - over on the Club Triumph website.
I'm not sure about mating the original 4 Spd/OD box to it but anything's possible with enough time/money :lol:
Not sure wether you'd have enough space for the turbo/manifold :)
KWM338R
#3 Post by KWM338R »
Thanks Lewis, just popped over there and had a look, his other "projects" look rather nice too!
SprintV8
#4 Post by SprintV8 »
That engine need's to be level and dropped down in the bay.
ITS 'TOO HIGH'
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
george
#5 Post by george »
looks as if it's just been droped in for a quick look as it still has the engine mount atached to the front and as it's derived from the 'o' series a 77 box would be the option for it as it was fitted to the sd1 2000l as well
MalcGE
#6 Post by MalcGE »
Seem to recall I saw a Marina/Ital with a L series 2.0 installed. Was at Bromley in about 2003 or 2004. Got a feeling the SD1 Sherpa TR7 box was used.
#7 Post by xvivalve »
There are a lot of MGBs around with this engine fitted too.
Morgans....
#8 Post by Jon Tilson »
were fitted with this setup out of the box weren't they? Non turbo though.
Thats the T series with a 5 speeder behind it...
It was also used in the Discovery MPI on an LT77 or R380 box so its doable. ANd of cousre the good old sherpa is O series on LT77 which should mean a T16 will fit.
george
#9 Post by george »
the 'o'series was fitted to mgb of the late variety with the 77 box iirc
Only....
#10 Post by Jon Tilson »
prototype george afaik to try and keep it in production a bit longer in the dark days just before the abingdon closure. Never made it out to the public but judging by marinas and princesses ambassadors and montegos I drove the O series is nothing special. Okay in a sherpa...
SprintV8
#11 Post by SprintV8 »
The O series is PANT'S.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
george
#12 Post by george »
yes it did.... saw some with it in not very many but they were out there might have been the 1700 version ????
and the 'o' series was used as a base for the t series pretty sure its the
same block casting ??
MalcGE
#13 Post by MalcGE »
Had an O Series 1.7 Ital Estate once, went like a rocket (for an Ital anyway) we never figured out why it ran so smoth and revved so willingly.
Mate of mine said you'll be alright until 80k miles, sure enough he was right, about 82k at 'a fair lick - no more pedal travel' on the M42, "BANG" #-o dropped the head off a valve, I just kept my foot to the floor, it rattled for a few tenths of a mile then settled down into a misifire, nearly made it home but I had to stop at a roundabout.
Pulled the head off, the valve head was wedged into the piston and had cracked the Piston and mullered the head. "2nd hand head, new piston and rod, put it back together, sweet as a nut :D
2F45T4U
#14 Post by 2F45T4U »
I saw a T16 today. Mates putting one in his 1.4 rover 25 :lol:
DavePoth
#15 Post by DavePoth »
T16 in a 25? that's pretty funny. If the engine is in good nick it will be a beast to drive with horrific torque steer and no traction control...
