Lt77 gearbox in a Dolomite
SprintV8
#16 Post by SprintV8 »
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
#17 Post by xvivalve »
LT77 should fit in a late 1850 easier than a Sprint as the splines on the input shaft are the same as a TR7 as is the clutch plate, therefore less to change.
Why though? We've been through pro's & cons of to do or not to do this swap before.
DavePoth
#18 Post by DavePoth »
I suppose if you have an LT77 in your garage, it's a much more attractive proposition that a sprint O/D box you don't have...
2F45T4U
#19 Post by 2F45T4U »
Are you trying to get me back from being catty with Jonners?
Yer why... as theres lots of bolts holding engines to gear boxes, I'd have to split the tr7 one from the lt77, then the dolly 7 from the 4 speed, then put the tr7 back on the 4 speed... That is the only reason :lol:
2F45T4U
#20 Post by 2F45T4U »
Will the prop mate with the out put flange, same bolt pattern???
Catty?
#21 Post by Jon Tilson »
Catty Adam? Surely not...just your normal humorous banter...
Like I often say, while we may rib you and therefiore get some back, we never forget that guys like you are the future....
So go for it if you want to....we'll all watch and have a laugh...
So who hanst got a spare Sprint box then? Cheaper and better if you ask me...
the prop flange is the same....cant say much about the length though.
slant4
why
#22 Post by slant4 »
4 sp o/d is far more fun - was good enough for the stag and tr5/6
So you welded up that tr7 yet?
You know a guy called Gareth in Doncaster? Think you maybe bro's
2F45T4U
#23 Post by 2F45T4U »
Yes just humourous banter
Yer I have an LT77 box and not an OD box.
Thing is I don't know what mood I'll be in on the day, may try it may not :P
SprintV8
#24 Post by SprintV8 »
4.2/4.5 T5 Cerbera
1st 2.95:1
2nd 1.95:1
3rd 1.34:1
4th 1.00:1
5th 0.80:1
Mine should pull more MPH in the first 3 gears then if I can get TRACTION.
And with two gear ratio's option's.
Wide ratio kit gearing:
1st: 2.915:1
2nd: 1.932:1
3rd: 1.323:1
4th: 1:1
5th: 0.8:1
Close ratio kit gearing:
1st: 2.527:1
2nd: 1.675:1
3rd: 1.259:1
4th: 1:1
5th: 0.87:1
LT77 SD1
1st 3.321:1
2nd 2.087:1
3rd 1.396:1
4th 1.00:1
5th 0.792:1
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
