welding Props
2F45T4U
welding Props
#1 Post by 2F45T4U »
Will a 130amp MIG welder with 0.8 wire in it weld up a prop shaft and keep it together even with a considerate amount of power going through it?
Adam
DavePoth
#2 Post by DavePoth »
No. To make the weld strong enough you'd need to use a lot of weld, which would unbalance the prop. not good. if it breaks you'll have a scaffolding pipe slamming against the floor of your car a few thousand times a minute and it won't take it that long to smash through.
Whather that's before or after it has dug itself into the road and flipped you over is another matter. :D
george
#3 Post by george »
you've not seen mythbusters then have you if a v8 with a tad more power than adams thinking about wont do it then it's mythbusted !!!!
but adam you really musn't think about that your'e thinking about
it needs to be stick welded and rebalanced after
i know a man that can !
2F45T4U
#4 Post by 2F45T4U »
Ooooh, you around tommorow and are you feeling strong? :P
Theres a prop shaft place by me, behind Day's in neath. I'l go talk to them when they re-open in the new year.
george
#5 Post by george »
yes but after 12:30 ish must earn my daily crust :(
is that barprops ?
2F45T4U
#6 Post by 2F45T4U »
Yer its BAR props. Are prop shops few and far between?
SprintV8
#7 Post by SprintV8 »
I'll go along with being rebalanced after but they can be migged.
Company that done my old RWD prop's used a lathe set on a very slow speed to turn the prop whilst mig welded up.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
2F45T4U
#8 Post by 2F45T4U »
If it's expensive to get made up I'll have a go, then attatch a device to catch the prop if it does unexpectiedly break, similar to a tennis racket with no strings :D
SprintV8
#9 Post by SprintV8 »
I wouldn't even attempt welding a prop myself and I've been welding since before you been born.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Lewis
#10 Post by Lewis »
......commonly known as a driveshaft hoop and found on most modified American cars.
Still gives you a bloody terrifying experience when one goes beneath ya - it's when it gets into the cabin that it becomes an issue :lol:
And yea, not something I'd try myself. One of the guys on our RR forum did one and got the joints incorrect (had 'em in phase), prop smashed itself to bits after a few hundred miles. He did some very nice welding, all the same.
2F45T4U
#11 Post by 2F45T4U »
Ok point taken. I'll see the man :D
DavePoth
#12 Post by DavePoth »
george wrote:you've not seen mythbusters then have you if a v8 with a tad more power than adams thinking about wont do it then it's mythbusted !!!!
Just trying to scare him George :D. I'd think the power-weight ratio would be a lot higher in a dolly, so it might be a bit more possible.
ALGIK
#13 Post by ALGIK »
Was at a rolling road a few years ago in Daventry ( Daventry rolling road as it happens) on power the car snapped its prop came through the car and smashed the guys arm that was doing the run
Was not a pritty sight
Get it done professionally
Work out how fast the prop turns at 7000 rpm engine speed in top gear
you will not comprehend it ....
Mr.Speedy
#14 Post by Mr.Speedy »
Where's the rolling road in Daventry?
I'm only in Braunston and i'm gonna wanna get the Sprintfire rolling road tuned and dyno'd.
