welding Props
welding Props
Will a 130amp MIG welder with 0.8 wire in it weld up a prop shaft and keep it together even with a considerate amount of power going through it?
Adam
Adam
No. To make the weld strong enough you'd need to use a lot of weld, which would unbalance the prop. not good. if it breaks you'll have a scaffolding pipe slamming against the floor of your car a few thousand times a minute and it won't take it that long to smash through.
Whather that's before or after it has dug itself into the road and flipped you over is another matter.
I'll go along with being rebalanced after but they can be migged.it needs to be stick welded and rebalanced after
Company that done my old RWD prop's used a lathe set on a very slow speed to turn the prop whilst mig welded up.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
I wouldn't even attempt welding a prop myself and I've been welding since before you been born.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
......commonly known as a driveshaft hoop and found on most modified American cars.attatch a device to catch the prop if it does unexpectiedly break
Still gives you a bloody terrifying experience when one goes beneath ya - it's when it gets into the cabin that it becomes an issue
And yea, not something I'd try myself. One of the guys on our RR forum did one and got the joints incorrect (had 'em in phase), prop smashed itself to bits after a few hundred miles. He did some very nice welding, all the same.
Just trying to scare him Georgegeorge wrote:you've not seen mythbusters then have you if a v8 with a tad more power than adams thinking about wont do it then it's mythbusted !!!!
but adam you really musn't think about that your'e thinking about
i know a man that can !
Was at a rolling road a few years ago in Daventry ( Daventry rolling road as it happens) on power the car snapped its prop came through the car and smashed the guys arm that was doing the run
Was not a pritty sight
Get it done professionally
Work out how fast the prop turns at 7000 rpm engine speed in top gear
you will not comprehend it ....
