sprint eng rebuild
triple tango
Re: sprint eng rebuild
#106 Post by triple tango »
when I degree'd my cam in I also noted that the crank pointer on front cover was 2 degrees out, I slotted the holes to adjust it.
trackerjack
#107 Post by trackerjack »
Finally about to start timing it all in as rebuilding the head has been more time consuming than I thought plus I have been doing one or two bits to raise a little cash to fund it.
trackerjack
#108 Post by trackerjack »
There is an error here can any one spot it?, it showed me that you are never too old to learn.
#109 Post by Mad Mart »
Nope! been staring at the photo for 10 mins. & I can't see the error.
Carl
#110 Post by Carl »
End cap missing from the rocker shaft ?
newguy
#111 Post by newguy »
Turbo manifold not bolted on yet?
2F45T4U
#112 Post by 2F45T4U »
3rd valve spring along upside down
rich
#113 Post by rich »
split pin for the end cap?
#114 Post by Mad Mart »
I think Adam's on the money!
#115 Post by xvivalve »
trackerjack
#116 Post by trackerjack »
congratulations Adam you are the winner 8)
I never even knew there was a right and wrong way round until I spotted it in the Haynes while skimming :shock: so off came the head and check the inlets too, only to find errors there :oops: if only I had not fitted new springs they would have been correct.
Now I have an important question cos my brain is not working well today.
What position in degrees relative to TDC should full lift occur on no 1 inlet?
The cam timing is given as 32/68 68/32.
At the moment the setting is full lift at 115deg ATDC and using a feeler the duration is 270deg.
My brain hurts :?
paulsprint
#117 Post by paulsprint »
Jon, the duration is 280deg and full lift is at 108deg ATDC on the inlets based on 32/68 68/32
hope that helps
triple tango
#118 Post by triple tango »
2F45T4U wrote:3rd valve spring along upside down
it makes me wonder how many other people have done that, & whether its really a problem?
Dolly racer 33
#119 Post by Dolly racer 33 »
I would think many people have done that. I do not suppose in the short term it would cause a problem but in the long term the spring would probably fail prematurely. However as most people on here are rebuilding there engines to get the maximum performance from it, you will lose power because the springs are the wrong way up. It will take more pressure to open the valve with the spring installed upside down thus robbing you of a little power.
If it did not matter there would not be a top & bottom. :D
triple tango
#120 Post by triple tango »
the new set I bought from Rimmers are the same both ends
