HELP! OD prob tracked down, but I need advice
Re: HELP! OD prob tracked down, but I need advice
#16 Post by xvivalve »
GrahamFountain wrote: Mon Jun 17, 2019 1:24 pm Oh well. I was hoping for a separate 4th, as I don't really want it on 3rd (or 2nd).
That's simple; don't flick the switch when in 3rd!
#17 Post by Mad Mart »
xvivalve wrote: Mon Jun 17, 2019 1:42 pm
...or you can weld up the detent in the selector bar!!!!!!!!!!!!!!!
GrahamFountain
#18 Post by GrahamFountain »
It's not, not flipping the switch in 3rd that's the problem as much as remembering to flip back before leaving 4th. But I guess the jump from OD4 to 3 would be nearly as annoying as OD3 to 2nd. Though perhaps not nearly so much as OD2 to 1st. That must be a bit of a shock.
Sundowner
#19 Post by Sundowner »
This is just my laziness speaking up here....
I see where Robsport sell a small wiring loom for Stags gearbox and overdrive.
https://robsport.co.uk/index.php/online ... on-gearbox
And the gear lever switch downwards is easily available too.
https://www.ebay.co.uk/itm/Triumph-STAG ... SwYHxWKh74
But, do any of the vendors make or sell a wiring loom for the Sprints gearbox and overdrive?
I emailed Simon at Robsport and got a NO from them.
Rob
#20 Post by soe8m »
I could if you or someone sends the old ones to copy.
#21 Post by tony g »
I really like it on 3rd. On an incline I like to hold 3rd then o/d it and if I start slowing just flick out and Im good to keep pulling. Its a bit odd when you forget its in o/d and shift from the 3rd to 4th and you get the slight delay though :).
Bish
#22 Post by Bish »
Sundowner wrote: Tue Jun 18, 2019 2:16 am This is just my laziness speaking up here....
Rob
Is this any good?
https://www.autosparks.co.uk/tp70-trium ... rness.html
Sundowner
#23 Post by Sundowner »
Bish wrote: Wed Jun 19, 2019 2:54 am Is this any good?
Yes its is Bish.
The plastic multi pin connector is different to my car, but is easily modified.
I'll order one ASAP.
Thanks & Cheers,
Rob
#24 Post by xvivalve »
Sundowner wrote: Wed Jun 19, 2019 4:20 am
Yes its is Bish.
Thanks & Cheers,
Rob
It doesn’t appear to include the bit that goes up the stick to the switch; the terminals there have to be very small in order to fit within the knob...
gmsclassics
For those who need reminding when overdrive is on!!
#25 Post by gmsclassics »
I had to resort to the large warning light - 18W amber on the right side of the dash. The red was 18W oil pressure warning. Worked but I'm sure a smaller version would be fine in a road car.
Geoff
Flyfisherman
#26 Post by Flyfisherman »
xvivalve wrote: Wed Jun 19, 2019 7:59 am
Yes its is Bish.
Thanks & Cheers,
Rob
Those terminals on the overdrive switch are small - i used 2.8mm spade terminals + some 1mm cable to renew mine.
GrahamFountain
#27 Post by GrahamFountain »
tony g wrote: Tue Jun 18, 2019 4:15 pm Its a bit odd when you forget its in o/d and shift from the 3rd to 4th and you get the slight delay though :).
I don't get that, it seems to stay in OD on the change.
I specifically checked this recently on the Herald, and that spitfire IV box (I think - reverse is up and left) stays in OD while in neutral, as long as the stick is over to the right hand side - I can hear the solonid operating with OD selected and moving the gear stick left-right in neutral. That used to have OD in all gears, including reverse. But it's better now.
I have yet to do that test with the Doly cos the mechanic who fitted the speedo cable disabled the OD - I assume he broke a wire. I intend to take the tunnel up and look at that asap.
#28 Post by tony g »
Its like the inhibitor switch momentarily disconnects then re-connects when the selector moves to 4th on mine.
