I've broken another front anti roll bar mounting. Any idea why?
GrahamFountain
Re: I've broken another front anti roll bar mounting. Any idea why?
#31 Post by GrahamFountain »
A search for these drop links came up with this. Considering it's just over a tenner inc drat, for the pair, one wonders if it might actually fit?
Okay
#32 Post by sprint95m »
GrahamFountain wrote: Tue Jul 21, 2020 8:56 am There're just spring washers under the nuts, nothing under the bolt heads. That's as I found them. I tighten the nuts with a spanner from the back, as I can only get a 1/4" drive on the bolt heads.
They should be nyloc nuts.
Ian
GrahamFountain
Re: Okay
#33 Post by GrahamFountain »
sprint95m wrote: Tue Jul 21, 2020 3:16 pm
Ian
Am I correct in remembering them as 3/8 UNF, 9/16AF?
Should they have washers under the bolt heads as well?
Aye.....
#34 Post by sprint95m »
The set screws are HU907, which translates as set screw with hexagon head 3/8"UNF x 7/8" long
(and the nylocs are part number YN2909).
They set screws should go in from the front according to the diagram in the parts book.
No washers are employed.
#35 Post by Carledo »
GrahamFountain wrote: Tue Jul 21, 2020 12:59 pm A search for these drop links came up with this. Considering it's just over a tenner inc drat, for the pair, one wonders if it might actually fit?
Cheapskate that I am, i'm still using second hand original droplinks on my cars! I'm pretty sure CW does a poly version, but they ain't cheap! ISTR someone else (or maybe it was early CW development ones) having a very short life expectancy with the threaded shaft snapping in short order. I also think I remember Jeroen offering or maybe experimenting with originals rebushed with poly of his own spec. Or I might have dreamed the whole thing!
In the absence of anything proven better, i've stuck to the Triumph product, but, of course, new or NOS are NLA!
That one you've pictured above looks like it might stand a chance, but a picture against a white background gives no idea of scale! Do you know what it's SUPPOSED to fit?
I've not really rejected ANY used ones yet as too far gone. Even with the rubber a bit cracked, they seem to work and not knock.
As I said, I remove them from the bar, clean and polish the bar end and replace them with a bit of grease on the bush and it seems to help, If I jack up the bottom ball joint with the car on stands (wheels off) I can SEE the bush move along the bar a bit as the arc shortens. TBH, I HATE removing the ARB, it's such a faff! But on both my cars I started with it off already, so why not?
Finally, I just noticed on a customer car I have in, it looks as if he has a pair of new repro links fitted, must ask him where they came from and how much!
Okay........
#36 Post by sprint95m »
Carledo wrote: Wed Jul 22, 2020 9:01 pmI'm pretty sure CW does a poly version, but they ain't cheap! ISTR someone else (or maybe it was early CW development ones) having a very short life expectancy with the threaded shaft snapping in short order.
Yes you're right Steve,
Chris Witor does sell new drop links with Superflex bushes for £30 each
https://www.chriswitor.com/proddetail.php?prod=153735P
The ones that failed were supplied by Jigsaw racing (who are no longer in business),
the failure was of the welds joining the bolt to the eye rather than the bolt itself.
For my own car, I have made new drop links using Superflex bushes (which I think cost something like £4 each).
I had to do this because I am using ST tie bars and the Dolomite links aren't long enough to fit.
