GrahamFountain wrote: ↑Tue Jul 21, 2020 12:59 pm
A search for these drop links came up with this. Considering it's just over a tenner inc drat, for the pair, one wonders if it might actually fit?
Cheapskate that I am, i'm still using second hand original droplinks on my cars! I'm pretty sure CW does a poly version, but they ain't cheap! ISTR someone else (or maybe it was early CW development ones) having a very short life expectancy with the threaded shaft snapping in short order. I also think I remember Jeroen offering or maybe experimenting with originals rebushed with poly of his own spec. Or I might have dreamed the whole thing!
In the absence of anything proven better, i've stuck to the Triumph product, but, of course, new or NOS are NLA!
That one you've pictured above looks like it might stand a chance, but a picture against a white background gives no idea of scale! Do you know what it's SUPPOSED to fit?
I've not really rejected ANY used ones yet as too far gone. Even with the rubber a bit cracked, they seem to work and not knock.
As I said, I remove them from the bar, clean and polish the bar end and replace them with a bit of grease on the bush and it seems to help, If I jack up the bottom ball joint with the car on stands (wheels off) I can SEE the bush move along the bar a bit as the arc shortens. TBH, I HATE removing the ARB, it's such a faff! But on both my cars I started with it off already, so why not?
Finally, I just noticed on a customer car I have in, it looks as if he has a pair of new repro links fitted, must ask him where they came from and how much!
