my dolly
lee666jd
my dolly
#1 Post by lee666jd »
just bought a 3/4 finished dolly 1850 manual paid £350
had a engine rebuid with £500 worth of paperwork so its fresh still not in the car not even done a mile yet
bodys not too babes had quite abit of the welding done to it 2 patches left (hopefully)
have a problem with the dizzy its not in the engine yet was wondering how 2 fit it properly as it will need timeing i think
other than that its a nice old car n im enjoyin playing with it
any advise is welcome as im new to triumphs i normally have opels
Re: my dolly
#2 Post by Toledo Man »
I have done this many times with Brown. Before you start setting the timing make sure you've got a decent set of points and condesnser fitted and correctly gapped.
First, get No. 1 cylinder at TDC. Align the notch on the crank pulley with the timing mark to achieve this.
Insert the dizzy so that when it is fully in the rotor arm should be pointing to the 2nd inlet manifold bolt from the back of the engine.
This will get the static timing correct so's you can start the engine. Once the engine's running you can set the timing with a strobe light. The original figure is 11 deg BTDC but the optimum figure can vary due to modern unleaded fuels. I'm sure others can advise on what has worked best for themselves. Don't forget to put some fresh fuel in the tank and make sure you've got a decent battery for a healthy spark! Duff batteries and stale fuel won't help much.
I hope this helps.
lee666jd
Re: my dolly
#3 Post by lee666jd »
yea thats helped alot everything is ready on the engine now its goin in 2moz weather permitting
theres loads a things that are new 2 me on this car its all pretty much the same as my kadett just odd things that are diff n im not sure what to do with e.g the tie bar rubbers where do i get them from ive typed it in on ebay but nothing any help with them /
That is easy as.......
#4 Post by sprint95m »
lee666jd wrote: the tie bar rubbers where do i get them from ive typed it in on ebay but nothing any help with them /
Superflex bushes are readily available from Chris Witor or Wins International.
Your engine has been rebuilt but not run yet?
In that case it'll need to be retorqued.......
Start it up and run up to normal temperature. Switch off and leave to cool down (overnight) then retorque.
Please use a proper torque wrench and please use the proper BL tightening sequence.
Retorque again after 500 miles.
It'll be worthwhile for you to purchase a genuine BL workshop manual?
These do appear on ebay.
Re: my dolly
#5 Post by Toledo Man »
BMH also do a CD-ROM with all the manuals in PDF format. Expect to pay around £20 depending on where you buy it.
The Superflex bushes are highly recommended. You can also get suspension bushes in Polybush from Jigsaw which I also recommend.
Let us know how you get on. If you need any pointers with the static timing I can take some photos to show where the crankshaft pulley and rotor arm should be when No.1 cylinder (the one at the front of the engine) is at TDC.
Well, you have never used one, have you .........?
#6 Post by sprint95m »
Toledo Man wrote:BMH also do a CD-ROM with all the manuals in PDF format. Expect to pay around £20 depending on where you buy it.
Where to begin?
I bought one of these from Rimmers a few years ago.
First problem, it only "works" with Windows :shock: . Which version is unclear after trying four different versions.
Using Windows 2000, it is possible* to access the files. However the indexes are numerical which means
you have to find things by trial and error. I dare say if you had all the manuals and parts catalogues to hand it
would be possible to cross reference the indexes :roll: .
The pages are photocopies. Many are illegible. A parts catalogue where you can't read the part numbers....... :!:
Describing this CD as a complete waste of money is extremely kind.
The words necessary to make a fair description are not permitted on this forum (or on TV before 21:00).
* There is a trick to gaining access which took ages to discover (by chance) :( .
Don't say I didn't tell you.
Rimmers are aware that this CD is windows only and did offer me a full refund.
Re: my dolly
#7 Post by Toledo Man »
Ian, mine works on every Windows XP PC I've tried it on. It can be a bit tempremental on the odd occasion. All the manuals I've read are perfectly legible. I've even printed out the entire post-76 Dolomite parts catalogue on my laser printer.
I bought mine from Rimmer Bros.
Re: my dolly
#8 Post by JPB »
Works with Windoze, yes, but Ian's saying that it only works with Windoze.
Ian, most 'Doze stuff will run under WINE on the superior operating systems that some of us use, perhaps that would provide a solution? :wink:
That said, the whole point of PDF is that the format is cross-platform capable so it ought to run under other systems. I have hundreds of circuit schematics and a fair few editions of Autodata on CDs that were made using Win 2K and they all read fine under Ubuntu 11.04 and Mac OS/X.
lee666jd
Re: my dolly
#9 Post by lee666jd »
i got myself a car manual and i have a snap on book with the touqe settings for the car
the engine is in the car now rad fitted just waiting from ebay a oil filter and plugs
do have a slight problem in the thermostat housing the little pipe has snaped i was wondering if i shoud e metal a new pipe in or get a new housing but there none on ebay
if any one has one i have alot of rare bits to swap let me know what ud want n ill see if i have them
Rimmer Bros
Re: my dolly
#10 Post by Rimmer Bros »
We now stock a DVD version of the Original Publications http://www.rimmerbros.co.uk/Item--i-HMCC7009DVD , works with Windows 2000 , XP, Vista and 7 and Adobe Acrobat 6,7,8 or 9.
Re: my dolly
#11 Post by Toledo Man »
The part number for the thermostat housing is UKC6916 and is currently listed as NLA on Rimmer's site. It is the same as the TR7 so you can try the TR supliers as well as the other usual suspects. If you can't get one you may have to repair your's bearing in mind that it will be subject to high temperatures and liquid (the coolant). This should help you to choose a suitable bonding agent.
Re: my dolly
#12 Post by Jon Tilson »
The soluion with these is to drill out the old steel broken pipe and get a new copper one threaded in. A local machine shop will do it for you for less than you will get another one.
lee666jd
Re: my dolly
#13 Post by lee666jd »
rite engines in and turning over sorted the thermostat housing out thats all conncted up just waiting for the filter to arrive now
i however have another problem with the full beem stalk its not workin the full beam or indicators but the horn is working fine if worse come to worse i will put them in a seperate switch
unless some1 has one goin ?
Re: my dolly
#14 Post by Toledo Man »
I just wanted to add the my CD-ROM doesn't work on Windows 7. I tried it in 2 laptops both running Win 7.
Sorry for dragging this off topic. Any further progress yet?
rpgrainger
Re: my dolly
#15 Post by rpgrainger »
how spooky drove past your car yesterday...i only live in fitzwilliam street
