Replacement coil for Lucas Type 15C6
Essexwriter
#1 Post by Essexwriter »
I'm pretty sure I need a replacement coil, and if I don't it certainly won't hurt - and will help me narrow down the possible causes for my troubles starting first thing in the morning and loss of power when the engine heats up.
My Toledo currently has a 6v Type 15C6 coil with ballast resistor incorporated in the wiring harness.
These don't seem easy to get hold of. I believe this type of coil was quite common, so I'm guessing some of you will have replaced it with an alternative.
My question is, what shall I replace it with? Any suggestions very welcome and gratefully received!
Cheers,
Ben
matt of the vivas
Re: Replacement coil for Lucas Type 15C6
#2 Post by matt of the vivas »
Use a Lucas DLB102 or equiv, or bypass the ballast resistor and use a DLB101 or a Sports Coil DLB105.
Matt.
#3 Post by Jon Tilson »
Our Jeroen swears by the Bosch red ones....
I'd just pinch a denso one off a nissan in a scrappie...
Essexwriter
#4 Post by Essexwriter »
Super - thank you both. As long as the replacement a) works and b) doesn't melt anything, I'm not hugely fussed about performance. Beyond being able to tackle hills, that is...
Cheers,
Ben
#5 Post by soe8m »
I alway's swear by red ones but a brunette is also fine for me.
80Sprint
#6 Post by 80Sprint »
:lol:
It certainly worked for me. Starts much better now especially when hot. :D
#7 Post by soe8m »
:-" very tempting but would be sooooo off topic.
kehoemj
#8 Post by kehoemj »
This is a 6V Lucas coil 15C6 fitted to a 1976 Sprint. I assume the ballast resistor is above the coil in the photo.
Would a straight replacement be the 12V Lucas DLB102 mentioned earlier in this thread?
I'm a bit confused to be honest.
15C6 Coil.JPG (243.76 KiB) Viewed 1963 times
Mahesh
#9 Post by Mahesh »
The bit above the coil looks like a suppressor.
dursley92
#10 Post by dursley92 »
The blue thing is a suppressor to prevent interference on the radio. The ballast is usually part of the wiring loom.
Russ Cooper
Dursley
UK
trackerjack
#11 Post by trackerjack »
I am looking after a Toledo for a friend and the ballast resistor in (my) car is a lump off stone attached near the coil.
Galileo
#12 Post by Galileo »
6v coil? :fingerwag: :posting:
