I have a few cylinder heads , apparently there are 2 types
How can you tell the differences
Many thanks
Sprint cylinder heads , 2 types ?
Re: Sprint cylinder heads , 2 types ?
Where the AE is embossed in a circle behind the front carb position, there will be a cast embossed figure '2' just to the right of it if it is a later head.
Many thanks for the info
Was there any differences between the early and late heads btw ?
I think AE just numbered the gravity die No 2 when production was stepped up.
Many thanks , I'll have to see how many of each type I have
Simon, there is a difference between early pre '75 and late heads.
MikeyB had the same problem as me on his early head, this is a quote from my thread. viewtopic.php?f=19&t=27969&start=345
The later head from 75 had a bigger water jacket & they compensated for the metal loss on the inside by adding extra metal on the outside, it's kind of re inforced around the top of the exhaust ports.
To identify the later head they cast a number two onto the very front of the head & another number 2 just ahead of the forward inlet port.
On early heads James you need to watch for binding springs, as I found to my detriment some of them have a machining fault on the spring pedestals. Machine 3mm to high.
See the backend of my resto thread.
Hope this helpsviewtopic.php?f=19&t=28447&start=135
You can see the heavier casting above the exhaust ports on Mart's head above
- trackerjack
I have never seen an early head but believe the counterbores for the springs were shallower and can cause the valve springs to become coil bound.
Many , many thanks for the info lads
Simon
Simon
