Front brakes.
brianrheffron
Front brakes.
#1 Post by brianrheffron »
Does the Works type front brake conversion, i.e. vented discs and
existing calipers spaced 10mm work with stock sprint alloys.
Re: Front brakes.
#2 Post by soe8m »
Yes.
Re: Front brakes.
#3 Post by Carledo »
You do need a replacement longer stub axle as well. I think Ken Clarke does these.
Re: Front brakes.
#4 Post by soe8m »
About 15 year ago i did fit these on a sprint of mine, genuine ST discs with spaced calipers but what i do remember is that it goes on a std hub with std stub axle. The only mod was fitting twin calipers.
brianrheffron
Re: Front brakes.
#5 Post by brianrheffron »
Thanks for the information and picture.
Next request is what are the key dimensions of the ST discs.
By deduction I'm quessing 221 diameter, 20 mm thickness
and depth O/A 36 mm.
Dolly racer 33
Re: Front brakes.
#6 Post by Dolly racer 33 »
These are not genuine ST discs Jeroen. The genuine ones were cast vented. Yours are cast solid then drilled.
