Temp Sender - what thread?
shaunroche
#1 Post by shaunroche »
Am I right in thinking that the thread in the inlet manifold for the temp sender is 5/8 UNF with a flat sealing face?
Ta.
Galileo
Re: Temp Sender - what thread?
#2 Post by Galileo »
Exactly that, with a copper washer.
I've changed mine to one with a warning switch connector that I'm planning on wiring up to a switchable buzzer. This one will show as running a bit hotter than the standard Smiths one as the resistance is more in keeping with modern gauges (VDO). Though that's easily adjustable with a resistor to earth, or moving the adjustment slot on the gauge itself.
http://www.ebay.co.uk/itm/Temperature-s ... 500064349?
