So that's where all the get up and go had got up and gone!
- GrahamFountain
- trackerjack
Re: So that's where all the get up and go had got up and gon
The usual drop in performance for a sprint is the bulkhead cracking/rusting beneath the throttle pedal bracket which allows it to bend and fail at giving full throttle.
- misterp
I wondered what the post actually meant..but makes sense if you are referring to the bit of the outer sheathing that is showing?
As a side, are there any instructions as to how to fit the cable?
Is the end that fits up to the bulkhead supposed to be free (i.e not captive)? Which side do you feed the cable into the engine bay from? Im assuming engine bay into the cabin and hook it over the pedal?
Sorry for the hijack, but relevant if Graham is fitting a new cable perhaps?
Yes its just a push fit in from the engine pay side and hook over the pedal. Dont loose the clip...
