JE pistons sprint
JE pistons sprint
#1 Post by tony g »
Hi does anyone have the part number for JE Pistons? Cant find it anywhere and I want to order from the states
gmsclassics
Re: JE pistons sprint
#2 Post by gmsclassics »
Tony, somewhere I'm sure I heard that Cambridge Motorsport have them made at JE, but to their own specification. If that is the case, they may not be available through a specific part number. Not sure how much CM charge?
In 2013 when I last built a motor (from a 1850 auto block), I got my standard diameter forged pistons from CP Carrillo to my own spec. I had to send an old piston over, but they said if I wanted any more, just to quote their job numbers.
If its of any interest, the customer no: 0456, job no: 204145, PO no: Dolomite. Spec sheet had the date printed as 30/7/2013. Happy to send you a copy of the spec sheet. I used new but standard rods and the engine builder bored and prepared the block to suit after the pistons arrived.
Geoff
#3 Post by tony g »
Thanks Geoff, that may be useful. Ive read on here 2 people at least have said they ordered from the states to save money so assumed they were on stock at JE (the sizes at least). I quite like CP actually ,have used them in a lot of forged (Jap) builds. If I need more info I'll give you a shout mate. BTW the Cambridge set is now over £800!
http://www.cambridgemotorsport.com/pistons/je322669
new to this
#4 Post by new to this »
not sure if sprint pistons are the same size as stag ones,peter t LD parts was going to get some remade,give him a ring
#5 Post by Carledo »
I think Stag pistons would be considerably smaller since a Sprint cylinder displaces circa 500cc and a Stag cylinder only 375cc(ish)
Neil907
#6 Post by Neil907 »
I think I may have a brand new set of JE pistons that I could be persuaded to part with.
I can have a look tonight if you want.
#7 Post by tony g »
Ok Neil let me know mate cheers
SprintMWU773V
TDC Staffs Area Organiser
#8 Post by SprintMWU773V »
I got my JE's when the £ vs $ was very favourable. If you deal with JE Direct you can do but expect them to be a bit awkward and not overly easy to deal with. That said what I got back from them was 4 superbly made pistons, perfectly equal in weight, seemed a shame to put them in the engine really. The Cambridge design is just a design, it's not their own unique one AFAIK.
Maybe someone like Omega has the necessary design already, they do forged and cast of exceptional quality and are based in Halesowen.
#9 Post by tony g »
Mark did yours come with a part number or just a customer ref?
I have contacted Omega on the weekend via their website but not heard back yet. About 6 years ago we used Omega for a load of toyota builds and there was a minimum order of 12 pistons, so if they have sprint details and can do an offer I was thinking of a group buy and see if theres interest here.
#10 Post by soe8m »
This was 2012.
#11 Post by tony g »
Cheers Ill search on that
SprintMWU773V
#12 Post by SprintMWU773V »
I would need to check my paperwork for the ref but the one quoted looks familiar for some reason.
#13 Post by xvivalve »
I have a new set of JP Australian made pistons that could be wrested from me...
PaulB
#14 Post by PaulB »
Tony,
I too would like a set of JE pistons. I tried a little while ago to contact JE in the States via email and got no reply.
If you make contact could you let us know?
Neil907
#15 Post by Neil907 »
It turns out the spare set I have are a set of Mahle pistons, if they are of interest to you let me know.
Cheers Neil
