I filled the tr7 engine with fresh coolant and now it's on the garage floor
It looks like it is dripping from the ledge under the carbs, I've tightened up the jubilee's on the bypass tube but I just cannot see where it's actually leaking from.
Any ideas please
Many thanks
Darren
1974 Triumph 1500TC In Maple Brown, (MABLE) GGN 647N 1968 Triumph Vitesse Saloon 2L MK2 Not for the faint hearted, mega restoration 1973 Triumph Spitfire In Mimosa
Sadly it sounds as if the water pump may have failed, or if you are lucky its the inlet gasket that has failed as this would leak water out just under the carb manifold up at no 1 cylinder.
Thank you gentlemen, would this be the same without the engine running, I should of mentioned above.
I have a gasket set so will have a good look tomorrow, and I can always nick a water pump from the engine that never got picked up by the ebay purchaser that's if 1850/tr7 are the same
Many thanks
Darren
Darren I would fill it up with water and have a look. Maybe the o-ring on the inlet manifold? The o-ring thickness is barely enough for the seal to be made.
I think it's sorted, I managed to get a bit more tension on the bypass tube rear hose clip and a slight weep from the back of the thermostat housing, so done up the bolts a bit more and seems to have sealed.
Idle's lovely and stays around the half way mark on the temp gauge, fingers crossed all's good. Will keep an eye on levels
Darren
I'm going to keep a close eye on things, I've got a few brake pipes to make and the clutch master to slave pipe as the end is a different size union to the 1500 slave size. See if I can can finally get the prop to fit and then hopefully a test drive is in order really miss driving it....
Darren
