Brake master cylinder
new to this
#1 Post by new to this »
Today i tired to remove the brake master cylinder,undone the two bolts either side but it wouldn't move,am i missing something ? Or is it they get stuck
cleverusername
Re: Brake master cylinder
#2 Post by cleverusername »
new to this wrote: Mon Aug 28, 2017 6:07 pm Today i tired to remove the brake master cylinder,undone the two bolts either side but it wouldn't move,am i missing something ? Or is it they get stuck
I have a master/servo cylinder from a 1500HL on the bench for painting, this is how I removed it.
1)Remove bracing bracket for servo (probably not needed for cylinder by itself)
2)Serve is held in by 4 nuts on inside bulkhead
3) Master cylinder is two nuts to servo, nothing more on mine. It did require a screwdriver to lever off due to corrosion.
Hopes that helps.
new to this
#3 Post by new to this »
cleverusername wrote: Mon Aug 28, 2017 6:14 pm
Hopes that helps.
Thanks at this moment im only taking master cylinder off,ill try a leaver just didn't want to go to mad and brake any thing
Thanks Dave
#4 Post by xvivalve »
The master cylinder does recess into the servo slightly and it is there that they can stick; gentle persuasion, plus gas and perseverance is all I can offer!
new to this
#5 Post by new to this »
WD40 worked got the brake master cylinder out,but found ive got one other thing missing :P i dont have a clutch hose,ill get one tomorrow, but does it go over the gearbox or under the box
#6 Post by xvivalve »
Over the gearbox to the slave which is mounted on the nearside of the gearbox body
new to this
#7 Post by new to this »
xvivalve wrote: Tue Aug 29, 2017 8:03 pm Over the gearbox to the slave which is mounted on the nearside of the gearbox body
Alun
thanks, are there any clips needed to keep the hose out the way or suport it
thanks Dave
#8 Post by xvivalve »
new to this wrote: Tue Aug 29, 2017 9:48 pm
Alun
thanks Dave
Often not, but there is a flexible clip which fixes under one of the gearbox top cover bolts that loosely holds the pipe
Magenta Auto Sprint
#9 Post by Magenta Auto Sprint »
I had the same problem on my 1850 HL.
as Alun said, plus gas, a bit of persuasion here and there.
Malcolm
new to this
#10 Post by new to this »
Magenta Auto Sprint wrote: Wed Aug 30, 2017 8:02 am I had the same problem on my 1850 HL.
Malcolm
Malcolm
Thanks i used WD40
new to this
#11 Post by new to this »
xvivalve wrote: Tue Aug 29, 2017 10:09 pm
Alun
thanks Dave
Alun
thanks,not sure if i have the flexable clip,when i get the hose ill make something up
thanks Dave
