Brake master cylinder
Posted: Mon Aug 28, 2017 6:07 pm
by new to this
Today i tired to remove the brake master cylinder,undone the two bolts either side but it wouldn't move,am i missing something ? Or is it they get stuck
Re: Brake master cylinder
Posted: Mon Aug 28, 2017 6:14 pm
by cleverusername
new to this wrote: Mon Aug 28, 2017 6:07 pm Today i tired to remove the brake master cylinder,undone the two bolts either side but it wouldn't move,am i missing something ? Or is it they get stuck
I have a master/servo cylinder from a 1500HL on the bench for painting, this is how I removed it.
1)Remove bracing bracket for servo (probably not needed for cylinder by itself)
2)Serve is held in by 4 nuts on inside bulkhead
3) Master cylinder is two nuts to servo, nothing more on mine. It did require a screwdriver to lever off due to corrosion.
Hopes that helps.
Posted: Mon Aug 28, 2017 6:59 pm
by new to this
cleverusername wrote: Mon Aug 28, 2017 6:14 pm
Hopes that helps.
Thanks at this moment im only taking master cylinder off,ill try a leaver just didn't want to go to mad and brake any thing
Thanks Dave
Posted: Mon Aug 28, 2017 7:39 pm
by xvivalve
The master cylinder does recess into the servo slightly and it is there that they can stick; gentle persuasion, plus gas and perseverance is all I can offer!
Posted: Tue Aug 29, 2017 7:46 pm
by new to this
WD40 worked got the brake master cylinder out,but found ive got one other thing missing :P i dont have a clutch hose,ill get one tomorrow, but does it go over the gearbox or under the box
Posted: Tue Aug 29, 2017 8:03 pm
by xvivalve
Over the gearbox to the slave which is mounted on the nearside of the gearbox body
Posted: Tue Aug 29, 2017 9:48 pm
by new to this
xvivalve wrote: Tue Aug 29, 2017 8:03 pm Over the gearbox to the slave which is mounted on the nearside of the gearbox body
Alun
thanks, are there any clips needed to keep the hose out the way or suport it
thanks Dave
Posted: Tue Aug 29, 2017 10:09 pm
by xvivalve
new to this wrote: Tue Aug 29, 2017 9:48 pm
Alun
thanks Dave
Often not, but there is a flexible clip which fixes under one of the gearbox top cover bolts that loosely holds the pipe
Posted: Wed Aug 30, 2017 8:02 am
by Magenta Auto Sprint
I had the same problem on my 1850 HL.
as Alun said, plus gas, a bit of persuasion here and there.
Malcolm
Posted: Wed Aug 30, 2017 4:33 pm
by new to this
Magenta Auto Sprint wrote: Wed Aug 30, 2017 8:02 am I had the same problem on my 1850 HL.
Malcolm
Malcolm
Thanks i used WD40
Posted: Wed Aug 30, 2017 4:36 pm
by new to this
xvivalve wrote: Tue Aug 29, 2017 10:09 pm
Alun
thanks Dave
Alun
thanks,not sure if i have the flexable clip,when i get the hose ill make something up
thanks Dave
