Wiring loom
new to this
Wiring loom
#1 Post by new to this »
I've got a couple of wiring questions
1/ what colour are the wires that feed the horn
2/ how are the wires run that feed the starter motor,do they run along the anti role bar
Thanks Dave
Re: Wiring loom
#2 Post by Mad Mart »
On a Sprint, purple & black wires to the horn +ve, black earth.
The wires for the starter are run inside the front rail of the subframe. There should be two holes in the subframe for plastic clips.
new to this
Re: Wiring loom
#3 Post by new to this »
thanks Mart
Found horn wide today,didn't see holes for the clips for starter motor
Thanks Dave
new to this
Re: Wiring loom
#4 Post by new to this »
Got another question,where does the live feed block mount,and can you get inside it to replace a cable ?
Thanks Dave
new to this
Re: Wiring loom
#5 Post by new to this »
does the live block/feed open up,if so how and where is it mounted to the car
Thanks Dave
Flyfisherman
Re: Wiring loom
#6 Post by Flyfisherman »
new to this wrote: Fri Jun 08, 2018 7:27 pm thanks Mart
Thanks Dave
The holes are the back side of the front cross member on the subframe
Re: Wiring loom
#7 Post by soe8m »
new to this wrote: does the live block/feed open up,if so how and where is it mounted to the car
Thanks Dave
It is attached to the starter cable around the alternator. It can open up but the wires have spade connectors so no need.
new to this
Re: Wiring loom
#8 Post by new to this »
Flyfisherman wrote: Sun Jun 10, 2018 8:48 pm
Thanks Dave
thanks I'll have a other look
new to this
Re: Wiring loom
#9 Post by new to this »
soe8m wrote: Sun Jun 10, 2018 10:53 pm
Thanks Dave
I think the battery cable is short, that's why I wanted to get inside the feed block,where is the feed block mounted
Thanks Dave
Re: Wiring loom
#10 Post by soe8m »
The feedblock is crimped to the startercable. When you have no starter cable you don't have a feedblock either.
Jeroen.
