Removing/replacing rear pillar / C post badges
GrahamFountain
#1 Post by GrahamFountain »
Any advice on how the C post badges come off the Doly Sprint and go back on?
GTS290N
Re: Removing/replacing rear pillar / C post badges
#2 Post by GTS290N »
They should just pull off, same as nose and boot badges. Two pins, pushed into rubber plugs.
GrahamFountain
#3 Post by GrahamFountain »
Thanks, was going to post that I'd done it. The one I've done was held on with one pin and some double sided tape. I thought there might be a clip under the C post bit of the headlining, but there wasn't.
GTS290N
#4 Post by GTS290N »
If I ever get round to having my new rear tonneau fitted the badge will be stuck on with tape.
GrahamFountain
#5 Post by GrahamFountain »
I'm replacing the vinyl trim on the C posts. I got some sticky backed leather effect vinyl off ebay for £5 per meter (450mm wide) I might have got both out of 1 m if I'd cut it with more care and parsimony, but I didn't. I thought, at that price, I'd have a go and see how it came out. Got a few bubbles to pinprick out, and some of the edges aren't perfect, but not too bad a job, and better than what was there, i.e. nothing. It went round the door jamb corner fairly easily, with help from a heat gun on low - might work with a hair-dryer.
Now I'll see if it lasts.
Need to get another piece for the other side. But anyway, I think I want some of the spare in fixing the parcel shelf base with 3mm hardboard sheet.
GTS290N
#6 Post by GTS290N »
GrahamFountain wrote: Sun Jun 23, 2019 11:54 am I'm replacing the vinyl trim on the C posts. I got some sticky backed leather effect vinyl off ebay for £5 per meter (450mm wide) I might have got both out of 1 m if I'd cut it with more care and parsimony, but I didn't. I thought, at that price, I'd have a go and see how it came out. Got a few bubbles to pinprick out, and some of the edges aren't perfect, but not too bad a job, and better than what was there, i.e. nothing. It went round the door jamb corner fairly easily, with help from a heat gun on low - might work with a hair-dryer.
Pictures would be appreciated. :)
GrahamFountain
#7 Post by GrahamFountain »
Ok pictures.
As you can see, far from perfect; certainly, if I'd paid a weeks wages for the job.
It did split a bit at the top rear because I didn't realize I needed the heat gun on that bit. So there, and an odd few other places, it needs a dab of black smoothrite with a fine brush.
And where it's stuck to the curve in the door jamb, it does nothing to hide the imperfections in the paintwork there. It's a bit thinner than the proper stuff.
But I find it acceptable for a fiver and half an hour's work.
Question is, what will it look like next year or the year after.
GrahamFountain
#8 Post by GrahamFountain »
BTW. It's mostly a different black because it's still clean.
GrahamFountain
#9 Post by GrahamFountain »
More vinyl turned up, so I did the other side. That went even better than the first side, but not so much better I'm going to re-do the first. There is enough in 1 m x 45 cm to do both sided if you cut it right.
Richard the old one
#10 Post by Richard the old one »
I believe that water was entering the boot of my car via the holes that hold the badges on as when I washed the car I watched the water run from the roof gutter directly down the down the C post to hit the badge. One of the plastic inserts that should hold the badge was missing so I have used some silicone sealant to stop the water leak.
GrahamFountain
#11 Post by GrahamFountain »
The driver's side one of mine only has one pin. But the snapped off bit is still in the hole. The other seems a reasonably tight fit I wouldn't have though enough water to notice would get through. But I'll look.
TrustNo1
#12 Post by TrustNo1 »
Richard the old one wrote: Thu Jun 27, 2019 9:31 am directly down the down the C post to hit the badge. .
There has been a lot of discussion in the past as to if it is a C or D post, my conclusion was it has to a D post otherwise Triumph wouldn't had fitted a badge with the letter D to them. :wink:
new to this
#13 Post by new to this »
Have you got the link of where to buy the vinyl from,
Thanks Dave
GrahamFountain
#14 Post by GrahamFountain »
