Can I have your comments please on OHV engine mounts.
Richard the old one
#1 Post by Richard the old one »
Last Thursday I visited Chris Witor to show him some examples of the 1300, 1500 and 1850 Dolomite engine mounts and he did state he would be able to get our engine mounts made out of Poly but that he would need to know if they were offset (See photo) and if so by how much as he had manufactured his initial Sprint poly engine mounts without an offset and has been told they need to have an offset so he has to get the mould modified which obviously costs money.
My son in law, Matt Cotton, recently obtained a couple which he believes to be new old stock metalastic and he has advised me that they are offset by about 12 mm.
I have looked at the old used mounts that I have kept and have found that :
I have 7 in number used old ones that were manufactured by Metalastic and these have offsets that range from 2 to 6 mm with an average of 4mm. The question is, were they manufactured with a 12mm offset and have sagged due to use?
I have 3 other old used ones, manufacturer and supplier, unknown, that do not have any offset.
I have 2 new ones, again from an unknown manufacturer and supplier, which have an offsets of 7 and 8 mm
I am also aware that Steve Waldenberg has recently purchased a new mount and that has an offset that varies between 2 to 4 mm.
Having an offset does mean that there must be a right and wrong way up to fit the mounts but having looked at the official workshop repair manual there is no reference to having to do this. I have always replaced them to give the engine the maximum lift.
Prior to going to see Chris I had sorted through my box of engine mounts and had selected a couple of old Matelastick mounts and a new reproduction engine mount. The old mounts had all been in service and the majority had been removed from cars because the rubber to metal bond had started to delaminate. Chris used a Durometer to determine the hardness of the various mounts. This turned out to be very interesting, the old Matelastic mounts produced readings of 60 and 70, so it looks as if one was a 1500 mount and the other was for a 1300 or 1850 engine. When Chris tested the reproduction mount it produced a result that Chris had not seen before its initial value was between 70 and 80 but then it dropped to a lower value of about 60.
I told him how for a long time I believed that all the Over Head Valve engines used the same engine mount, a part number 158016, but that I was then told that the 1500 engine should have a harder rubber mount than the other engines and that the difference was distinguished for a period by a
coloured paint mark on the mount. The availability of mounts with different hardness seems to have stopped at some point in time and it is only fairly recently that I happened to look at the official triumph dolomite parts catalogue and discovered that original 1500 Dolomite engine mounts were a part number 149934 which I assume was manufactured with harder rubber.
I am looking for comments on (a) whether you believe the mounts should have an offset or not and if they should what the amount should be (b) were you aware that there is a right and wrong way up to fit the mounts? Plus do you agree that when the engine mount is fitted it needs to be fitted to give the engine the maximum height?
DOLOMITE 135
Re: Can I have your comments please on OHV engine mounts.
#2 Post by DOLOMITE 135 »
I have 4 off NOS Metalastik engine mountings, 3 off with pink(ish) paint markings (two of these have Mick Dolphin labels stating they are 158016 engine mount soft 1850 Dol), the fourth has a brown paint mark. The three pink marked mounts I can feel slight movement when I try to flex them, the brown marked mount has little to no flex by comparison.
I have roughly measured the offset on mine with the results in the photos below, hope this helps:
Engine Mounts.JPG (60.03 KiB) Viewed 996 times
Engine Mounts 2.JPG (93.37 KiB) Viewed 996 times
Engine Mount1.JPG (66.61 KiB) Viewed 996 times
Engine Mount2.JPG (63.25 KiB) Viewed 996 times
Engine Mount3.JPG (64.61 KiB) Viewed 996 times
Engine Mount4.JPG (65.6 KiB) Viewed 996 times
tinweevil
#3 Post by tinweevil »
Hi Richard,
I have some NOS I've been meaning to measure since seeing your post, bit hectic here at the moment. Tomorrow with luck.
#4 Post by xvivalve »
I have a pair of NOS Sprint ones somewhere, if I find, I'll measure.
Personally, my opinion is given the manufacturing process uses heat, they will all be different due to random distortion
tinweevil
#5 Post by tinweevil »
By the same measurement method as above I get 8.8, 8.3 & 8.5mm. All Metalastic NOS, soft, hard & hard respectively.
Richard the old one
#6 Post by Richard the old one »
Many thanks for the details that fellow dolomite owners have sent in. I will give a bit more time for others to read and respond and then I will get in touch with Chris again.
It does not look as if we will be using our cars much for some time so there is not too much of a hurry.
Richard the old one
#7 Post by Richard the old one »
I happened to see the Lewis Coleman wrote on the Triumph Dolomite Facebook group on 3rd April that he had purchased some new engine mounts but that they turned out they are from an 1850 so the engine wobbles around like jelly. This is yet more confirmation that the 1500 engine needs stiffer mounts.
new to this
#8 Post by new to this »
Richard the old one wrote: Sun Mar 22, 2020 8:51 pm Many thanks for the details that fellow dolomite owners have sent in. I will give a bit more time for others to read and respond and then I will get in touch with Chris again.
I see chris now list engine mounts for the 1300 and says Sprint Due in,it doesnt say if 1300 mount could be used for 1500
Richard the old one
#9 Post by Richard the old one »
I believe that Chris has currently only produced engine mounts for the 1300 FWD drive cars which would not be suitable for a 1500 Dolomite.
