Build dates
georgethompson730
Build dates
#1 Post by georgethompson730 »
Hi everyone, anyone out there got a VIN No. near mine so I might be able to guess my build date. Just out of curiosity really as you can't get a Heritage Certificate sent out at the moment.
First reg. 30/09/1980
VIN/Chassis No. TWFLC5AT111073
Thanks in advance.
Re: Build dates
#2 Post by xvivalve »
You can't get a full Heritage Certificate at the moment, but they will e-mail the date of production to you
https://www.britishmotormuseum.co.uk/ar ... rtificates
SprintV8
Re: Build dates
#3 Post by SprintV8 »
Mine has a build date of 21st April 1980
(Forty years Today).
Verify by Heritage Certificate
And first reg 12th September 1980..
Vin number TWTLD5AT108782
I believe she may have been a dealer demo.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
marshman
Re: Build dates
#4 Post by marshman »
As far as I can see you still have to pay for the full priced paper certificate, but you won't receive it until the museum re-opens. They will however email you a copy at no "extra" charge. Unless anyone knows different.
Roger
1971 Stag Auto White
Re: Build dates
#5 Post by xvivalve »
If you pay £6 they will tell you one item of information from the Certificate by e-mail.
See 'web research request':
https://www.britishmotormuseum.co.uk/ar ... d-delivery
georgethompson730
Re: Build dates
#6 Post by georgethompson730 »
Thanks everyone, pretty much what I had worked out about the museum being closed. At 108000 and mine being 111073 still a few being made after 23rd April. Going to have to pay the £6 I think. Anyone know the last VIN.no. for 1850's , I think mine might be quite a late one.
Re: Build dates
#7 Post by Carledo »
georgethompson730 wrote: Tue Apr 21, 2020 9:08 pm Thanks everyone, pretty much what I had worked out about the museum being closed. At 108000 and mine being 111073 still a few being made after 23rd April. Going to have to pay the £6 I think. Anyone know the last VIN.no. for 1850's , I think mine might be quite a late one.
I may be mistaken, but I think the final Sprint is something like 113118 and this was the last Dolomite built. Someone will know and no doubt derive small pleasure from correcting me!
EDIT James467's late Sprint NWLxxxW, reckoned to be one of the last 10 Sprints built, is 112876, so the number I quoted above is fairly close! NWL was built in August of 1980, so you have a bracket, I'd put 111073 at late June/early July.
SprintV8
Re: Build dates
#8 Post by SprintV8 »
Vin updated
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
RichardHyde
Re: Build dates
#9 Post by RichardHyde »
For the £6 email enquiry will they tell me the paint code of BPM663T ?
It was my first Sprint purchased in 1987. It was a darker green than my current HAE green Sprint.
Thanks, Richard
Richard the old one
Re: Build dates
#10 Post by Richard the old one »
I was advised by the archive department at Gaydon that my 1500HL chassis/commission number TWFLW5AT/110567 has a build date of 18th June 1980 so not far from your car in production.
Re: Build dates
#11 Post by xvivalve »
RichardHyde wrote: Wed Apr 22, 2020 7:50 am For the £6 email enquiry will they tell me the paint code of BPM663T ?
Thanks, Richard
They will tell you one item of information from what they hold; it will likely give you the code, but it could be the colour name, or it could just be generic 'green' all dependent on what they hold.
You'll need the chassis number though as the registration was not allocated at the factory.
tangocharlie1
Re: Build dates
#12 Post by tangocharlie1 »
No pleasure taken from this Steve :D
But want it to clear it up so it can be used as a baseline.
The last Sprint at British motor museum is
TWTLD5AT113504
1973 Triumph Dolomite Sprint
1972 Triumph Stag
1973 Triumph TR6
georgethompson730
Re: Build dates
#13 Post by georgethompson730 »
Well sent my £6 last night and woke to a refund and a message 'Unfortunately the factory record for your car has not survived.' how sad is that!
I'll never know it's birthday unless someone has the car or two right next to mine. Late June early July is a good guess, thanks everyone.
Replied to their email just to make sure I gave the correct VIN and got this very interested reply, well I thought so :)
Dear Mr Thompson,
Yes, that is the VIN you provided. To explain the situation, the Triumph factory records have only survived as microfilmed build cards, which have since been digitised. Unfortunately the VIN sequence jumps from 111071 to 111076, meaning the sheet which contains your car's record was never microfilmed. As to why this was, we can but surmise, the most likely explanation being it was damaged and rendered unreadable. It is fair to say that not much trouble was taken when the microfilms were created. From the other records we can estimate your car was built 4 July 1980, however because we do not have the car's record, we are unable to state this as fact, or be able to produce any document for the car.
tangocharlie1
Re: Build dates
#14 Post by tangocharlie1 »
How unlucky is that, chances our yours is the only car that survives in that small quantity of numbers anyway.
1972 Triumph Stag
1973 Triumph TR6
Re: Build dates
#15 Post by xvivalve »
tangocharlie1 wrote: Wed Apr 22, 2020 10:08 am No pleasure taken from this Steve :D
TWTLD5AT113504
Steve was sort of mixing up the last number used in the VA series!
