One for Carledo...
matt of the vivas
One for Carledo...
#1 Post by matt of the vivas »
Mr Carledo sir....
You mentioned in the past you used to fit sunroofs.
Im wondering if you can identify the make of the one fitted to my Dolomite, more out of interest than anything else.
I know it was fitted brand new in 1972, its listed on the bill of sale.
Theres no makers name on it anywhere. I know its not a proper Webasto as its not wood framed.
I often look at cars at shows with similar roofs but never seen one the same as this, with the chrome handle sticking out - most of the others seem to use a recessed black handle.
Could it be an early Weathershields?
Thanks - Matt.
Re: One for Carledo...
#2 Post by Carledo »
Yes mate, it's an early Weathershields roof, the visor is unmistakeable!
matt of the vivas
#3 Post by matt of the vivas »
Thats great, thats what i thought thanks! If i ever need to remove it, im assuming the row of screws through the rear of the headlining retain the rear part?
#4 Post by Carledo »
matt of the vivas wrote: Fri Apr 24, 2020 11:34 pm Thats great, thats what i thought thanks! If i ever need to remove it, im assuming the row of screws through the rear of the headlining retain the rear part?
That's it! Good luck getting them out after all this time though! The other bars just twist out, with the roof mostly open, pull 1 bar forward at a time and deliberately get it out of parallel with the front frame and it'll come free. Then repeat for each successive bar.
My missus had a Weathershields roof in her 63 Herald, the handle on that looked just like yours. By the time I was fittng them in the mid 70s, they'd gone over to the sleeker (and safer) recessed handle, usually a chrome pull down and twist job in a black plastic frame!
Steve28
#5 Post by Steve28 »
Many years ago i remember my dad had a Valencia blue 1500 fwd with the same sunroof that was fitted when new
it was a company car at the place he worked at and he bought it when it was 1 year old off them.
steve
1973 yellow Sprint L reg
1979 1500 SE T reg
1979 1500 SE V reg
1980 vermillion 1500hl W reg
1975 green 1500tc auto P reg
1973 Brown Toledo 2 dr L reg
1973 Green Toledo 2 dr L reg
1983 White Toyota Tercel 4x4
1987 Brown Toyota Tercel 4x4
1988 Blue Toyota Tercel 4x4
1999 Toyota Corolla vvti est
2005 Ford ranger thunder XLT
