Sprint or 1850 gearbox tunnel?
Pen
#1 Post by Pen »
Can anyone tell the the difference between the two, does the sprint box fit inside the 1850 tunnel ?
Cheers ian
Re: Sprint or 1850 gearbox tunnel?
#2 Post by Carledo »
The late 1850 (single rail) gearbox tunnel has the gearlever hole displaced about an inch to one side, whereas the Sprint hole is central. There may be some slight discrepancies with the mounts for the coin tray/console too. But the overall shape is similar. You could probably make it work if you were desperate! It's the only one that stands a chance, the OHV tunnels are too narrow for a Sprint box and auto variants are too low.
PS if you CAN'T make that work, I believe the club can still supply a GRP tunnel to order for Sprint only.
Pen
#3 Post by Pen »
Cheers for the info Steve top man , think I will contact the club closer the time of the swap out for a grp sprint one 👍🏻
Cheers ian
