Does length of the prop shaft on the Sprint differ with and without overdrive, like on the small chassis cars? And what length is the overdrive one, 50"?
Sprint propshaft length?
- GrahamFountain
Re: Sprint propshaft length?
Manual non-O/D and O/D Sprint props are the same length. Only the Automatic one is different (an inch or two shorter) 50" is right for a manual car IIRC.GrahamFountain wrote: ↑Wed Apr 28, 2021 11:21 am Does length of the prop shaft on the Sprint differ with and without overdrive, like on the small chassis cars? And what length is the overdrive one, 50"?
- GrahamFountain
Thanks Steve. Much obliged.Carledo wrote: ↑Wed Apr 28, 2021 4:27 pmManual non-O/D and O/D Sprint props are the same length. Only the Automatic one is different (an inch or two shorter) 50" is right for a manual car IIRC.GrahamFountain wrote: ↑Wed Apr 28, 2021 11:21 am Does length of the prop shaft on the Sprint differ with and without overdrive, like on the small chassis cars? And what length is the overdrive one, 50"?
Isn't the auto prop longer; the auto' 'box being slightly shorter than the manual and no adaptor plate being used?Carledo wrote: ↑Wed Apr 28, 2021 4:27 pmManual non-O/D and O/D Sprint props are the same length. Only the Automatic one is different (an inch or two shorter) 50" is right for a manual car IIRC.GrahamFountain wrote: ↑Wed Apr 28, 2021 11:21 am Does length of the prop shaft on the Sprint differ with and without overdrive, like on the small chassis cars? And what length is the overdrive one, 50"?
...but yes, 50" is the manual length.
- GrahamFountain
Thanks for confirming the length.xvivalve wrote: ↑Wed Apr 28, 2021 8:19 pmIsn't the auto prop longer; the auto' 'box being slightly shorter than the manual and no adaptor plate being used?Carledo wrote: ↑Wed Apr 28, 2021 4:27 pmManual non-O/D and O/D Sprint props are the same length. Only the Automatic one is different (an inch or two shorter) 50" is right for a manual car IIRC.GrahamFountain wrote: ↑Wed Apr 28, 2021 11:21 am Does length of the prop shaft on the Sprint differ with and without overdrive, like on the small chassis cars? And what length is the overdrive one, 50"?
- gmsclassics
Re: Automatic Sprint propshaft length?
Just for the record the Sprint Automatic propshaft is just over 55inches (1.40m). Geoff
