Beam me up !!
RichardHyde
Beam me up !!
#1 Post by RichardHyde »
Doing some re-wiring and need to check I’ve got it right.
When I pull the ‘horn’ stalk towards me the ‘beam’ comes on correctly eg flashing the lights.
Are there any pre-conditions to get the ‘beam’ on when pushing the ‘horn’ stalk forwards eg lights constantly on ? Main or side lights on ? Ignition on ?
Thanks, Richard
RichardHyde
Re: Beam me up !!
#2 Post by RichardHyde »
False alarm…turned out to be very bad contacts on the indicator stalk…
naskeet
Re: Beam me up !!
#3 Post by naskeet »
RichardHyde wrote: Mon Sep 27, 2021 9:38 pm False alarm…turned out to be very bad contacts on the indicator stalk…
Bad contacts are a common problem with these combination switches, arising partly from the design and the oxidation of the crimped & rivited connections. :cry:
I suffered one MOT failure, because the dip switch failed during the MOT inspection, having been okay in the days, weeks & months leading up to the event! :evil:
Ideally, the crimped wires should have been lightly soldered where the bare-wire crimping was done, then strain-relieved and sealed using hot-melt glue & heat-shrink sleeving.
Regards.
Nigel A. Skeet
