Chrome trim
Malsprint
Chrome trim
#1 Post by Malsprint »
Is there a special tool or technique for removing the chrome trim on the side of the car. Without kinking or marking it.
Ralph
Re: Chrome trim
#2 Post by Ralph »
I bought a set of trim removing tools from my local car accessory shop which I used for taking the door panels off without destroying the clips/panel. Most are tapered plastic and although I have not used them on the side trim I daresay there is a tool in the set that would do it. Suggest you see what is available at your local shop.
Ralph
Malsprint
Re: Chrome trim
#3 Post by Malsprint »
In the absence of something off the shelf I modified a 1/2” spanner to do the job.
Malsprint
Re: Chrome trim
#4 Post by Malsprint »
Trim Spanner Photos
Trim spanner 2.jpg (77.38 KiB) Viewed 2062 times
Trim spanner 1.jpg (61.54 KiB) Viewed 2062 times
new to this
Re: Chrome trim
#5 Post by new to this »
Malsprint wrote: Fri Jun 16, 2023 9:27 pm Trim Spanner Photos
How are you going to refit the trim ?
Re: Chrome trim
#6 Post by Carledo »
new to this wrote: Fri Jun 16, 2023 9:49 pm
Hook it over the top and whack it with the heel of your hand. Sure it hurts a bit if you've not practiced, but it doesn't damage the trim. For best results, start at the curve at the top of the A post.
Taking it off I just use a pair of pliers over thin cardboard, ie Weetabix box. Clever tool though, Kudos!
