Fuel pump fitment
Fuel pump fitment
Anyone had trouble fitting a QH fuel pump on a Sprint?
Seems to be a tricky blighter - played around for 10 mins but left it as getting annoyed.
Is there supposed to be a spacer at all ?
Let me know
Let me know
VW Mk1 Golf GTi Campaign - Alpine White (A reg)
Dolomite Sprint - Magenta (M reg)
Vauxhall Omega MV6 - Champagne (S reg)
BMW Alpina B10 3.3 Touring (51 reg)
Re: Fuel pump fitment
What is the length of the arm?
It measures 60mm from end of body to tip of lever (max length)
Part number is QFP33
Yes, that model requires a spacer; you'll find two gaskets in the box, one for each side of the spacer (but no spacer!)
A non spacer armed pump is just shy of 50 mm.
Thanks - that answers the question.
Seen some on eBay - mainly for Mini but are these the same?
Ridiculous they don’t supply spacer
When I replaced my fuel pump some years ago I did a drawing of it and the Long Arm replacement ( Attatched )
If you print the graph paper out full size ( the squares are 1cm x 1cm ) and place the edge of the fuel pump on the left hand side you can check whether it is an early or a late version. Fig 1 is the early one. Fig 2 is the late one and Fig 3 is the late one fitted with the UKC 8523 plastic spacer.
HTH,
HTH,
- slant4 fuel pump shrink.jpg (53.72 KiB) Viewed 4786 times
Thanks for that - seems spacer is order of the day
I think they expect you to re-use your existing spacer.
Bit tricky if you are replacing a short armed one without the spacer!
Russ Cooper
Dursley
UK
Dursley
UK
- TDC Cheshire Area Organiser
I just used two mini ones, only because i had them and they work fine.
NOW A CLUB MEMBER 2017057
