Sprint solid carb mounts
Hi everyone,<br>
Just thought I'd ask for some advice.<br>
I have a sprint where the carb mounts have split (SU). The club stocks solid mounts and I was woundering if this was the way to go? <br>
Has any one any experience of these mounts, I have also heard tell that these can cause frothing due to vibration. <br>
Any thoughts would be welcome.<br>
Cheers Rob
Cheers Rob
Re: Sprint solid carb mounts
Definitely the way to go, no question. The option is remanufactured mounts which last about a week!<br>
I have had no issues with either cavitation of the fuel or undue heat transfer.
Mike Groom
Mounts
I agree.<br>
Fitted mine a few months ago. Also had alot of interest at the Malvern show! No problems with fuel, even seems to go better, but that could be the other bits I fitted at the same time!
i have them
I have them fitted to mine, never had any problems with air leaks.
DailySprinter
well worth fitting
Much better than original, no problems encountered at all.<br>
It was good enough on my Bentley Mk6 to fit SU's directly on the inlet manifold without rubber mounts, if it's good for Bentley it must be good for Triumph
Mounts
Thanks for all the replys, You,ve got me convinced.<br>
I,ll order some mounts from the club tonight or tomorrow<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
Re: Mounts
I could write you a huge list's of car's that use SU's carb's that are mounted with no Flexy Mount's and have no trouble at all.<br>
<p>1980 Dolomite SprintV8 (In the process of modifying the Alloy sump)<br>
They laugh at me because I am different. I laugh at them because they are all the same!)<br>
</p><i></i>
</p><i></i>
Re: Mounts
I've been running solid mounts since 2004, no problems. <br>
Apparently, so legen has it, Fuel Frothing only occured when 'bench running' Dolomite Motors. The problem could never be re-created on the road. <br>
Perhaps by the time BL found out they already had rubber mounst in production.
