Project "Nugget" - 1980 Brooklands Green 1500HL Auto
If I may,............
#106 Post by sprint95m »
Just to add to Mart's post,
please fit new nyloc nuts. (These are 1/2"UNF.)
Cheesy
Re: Project "Nugget" - 1980 Brooklands Green 1500HL Auto
#107 Post by Cheesy »
Thanks for the replies! Yes, new nylocs will be used. :D
Just went out to the garage to have a quick look at the problem, and discovered that both rear cups have gone! :shock: The subframe has dropped at the back, it's a good job that my wife didn't carry on driving.
I am now wondering if one had already gone, causing the strange engine vibrations we've been getting, and eventually the strain proved too much for the other one.
A pair of new cups, lower rubbers (one has disappeared), bolts and nuts have been ordered and will be fitted as soon as they arrive.
Cheesy
#108 Post by Cheesy »
Mmmmmm, it shouldn't really look like this! :shock: Especially not when it's BOTH sides.
#109 Post by Jon Tilson »
That is undoubtedly what happened.
I have had this happen to me twice....once just like you when the remaining one dropped. I hadn't realised the other side had gone either. This was in the Sprint and luckily only a mile from the house...after the normal 40 mile commute home on the motorway at the usual continental....so I got away with it but the last mile was interesting.
Also happened to the yellow peril. I retrieved the bits from the road and refitted some spare ones within 5 minutes of getting back home. Once bitten...
You can get and I have on some of my fleet a non cupped poly rear sub frame mounting with a flat base, and this uses a big flat washer instead of the cup.
This cant rust away invisibly cos its stainless too.....but needs a slightly longer bolt which it came with, and a mounting spiggot too.
Not sure if you can still get this kit but worth finding.
Howard81
#110 Post by Howard81 »
Yikes, that's nasty :shock: Glad it happened not to far from home.. a simple fix at least.. and a good opportunity to slip in some poly mounts :mrgreen:
How has she been holding up to everyday use? :)
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
Cheesy
#111 Post by Cheesy »
Howard81 wrote:How has she been holding up to everyday use? :)
Holding up very well thanks Howard. Starts, runs and drives great.
The engine vibrations coming through into the cabin have been annoying, but perhaps that was down to one subframe mounting already being broken, should find out later this week!
One problem is an oil leak from the rear of the engine. Looks like it is the rear crankshaft oil seal, so it may be gearbox out time. :( Do you know if any seals were changed when you had the engine rebuilt?
Apart from that, going very well! :D
Jod Clark
#112 Post by Jod Clark »
They all were, as you'd expect. Are you sure its engine oil and not transmission fluid?
Cheesy
#113 Post by Cheesy »
Jod Clark wrote:They all were, as you'd expect. Are you sure its engine oil and not transmission fluid?
Yes, definitely engine oil. :( My wife is on holiday soon for the summer so won't need the car for a while, so I will get chance to investigate further.
Changed the subframe washers last night, there wasn't much left of the old ones! :shock:
#114 Post by DoloWIGHTY »
:o Jeepers they did need doing! :shock:
#115 Post by JPB »
*Clears throat*. SOMEONE, let us refer to him as "X" Didn't know that these cups were obtainable new, so, on discovering that those on his own car were almost at the point of breaking through, carefully repaired them with dished repair washers. If only I... sorry; someone :( :oops: had known that he could have saved himself hours of measuring, grinding, welding, more grinding, turning, more grinding, etc. :oops:
Still, looking on the bright side; at least doing this job gives you the chance to have a good poke to make certain that the surrounding metalwork is all good.
Cheesy
#116 Post by Cheesy »
As some of you may have seen, Nugget is now up for sale. :(
My wife has not taken to classic motoring as much as she'd hoped, and we are now looking for a more modern car for her. It would be a shame to see Nugget deteriorate through lack of use, so we have decided to sell.
Anyone who has read this thread over the past few months will know the work that has gone into making Nugget a reliable, solid and tidy every day car. I've put some information in the For Sale section of the forum, if you are interested please PM me, it would be nice to see her stay in the TDC.
Thanks for all the help and advice over the last few months.
Steve28
#117 Post by Steve28 »
The same thing happened to my 1500se at easter but the washes looked in good condition apart from under the nuts rotting, and when mine went it also pulled on the steering column pulling the bulkhead bush out.
And it went as i was pulling out of a parking space and not at 50 mph as i had been doing within the previous hour, which was vey fortunate.
1973 yellow Sprint L reg
1979 1500 SE T reg
1979 1500 SE V reg
1980 vermillion 1500hl W reg
1975 green 1500tc auto P reg
1973 Brown Toledo 2 dr L reg
1973 Green Toledo 2 dr L reg
1983 White Toyota Tercel 4x4
1987 Brown Toyota Tercel 4x4
1988 Blue Toyota Tercel 4x4
1999 Toyota Corolla vvti est
2005 Ford ranger thunder XLT
