Sprint throttle return springs
Hello,
Having successfully transformed my Sprint after rebuilding the carbs, I'm having all sorts of trouble trying to locate some "correct" throttle return springs.
2 of the 3 I have, have been stretched and bent up by previous owners.
They are 3.5" long, but the best I can find are 2.75" and although the 2.75" ones stretch to fit, they are then too stiff to drive comfortably.
I've searched Burlens, Rimmers, SU Midel, eBay, etc, etc; without luck.
I'm looking for either good used or new. Can anyone point me in the right direction please?
Cheers,
Rob
Cheers,
Rob
Re: Sprint throttle return springs
sure these are the ones http://www.ebay.co.uk/itm/TRIUMPH-DOLOM ... SweW5Veu8C
also here at Rimmers but much dearer
http://www.rimmerbros.co.uk/Item--i-159463
Thanks for that, but they aren't the same.
The pic shows an original 3.5" Sprint spring (the only good one I have) and the shiny one that the vendors sell. I have a set of 3 of those and all they do is make the accelerator pedal really hard.
I could make up some sort of lengthening loop for them to hook into. A small key-ring perhaps. But I'd like the right springs if I can get them.
Once again, Thanks.
Cheers,
Rob
Once again, Thanks.
Cheers,
Rob
- DSC06565 (1521 x 1140).jpg (295.72 KiB) Viewed 1333 times
Try part number 153959 on Paddock website.
Thanks for the part number Paul. Much appreciated.
Its the correct part and I've just ordered a set.
Again, my thanks.
Cheers,
Rob
Again, my thanks.
Cheers,
Rob
And for £1.08 http://www.leacyclassics.com/153959.html
Rob, I think you've got the 1850 springs. They look similar to the new ones I bought recently.
Yes, I'm pretty sure you're right.Toledo Man wrote:Rob, I think you've got the 1850 springs. They look similar to the new ones I bought recently.
Why they're not marketed as being for the Sprint too, is strange.
I know my Sprint is unchanged from factory and the springs are original.
Anyway, its all sorted now, thanks to this forum and the people who frequent it.
Cheers,
Rob
I got these and they're fine.
If they weren't then believe me they would have known about it!!
