Sprint throttle return springs
Sundowner
#1 Post by Sundowner »
Hello,
Having successfully transformed my Sprint after rebuilding the carbs, I'm having all sorts of trouble trying to locate some "correct" throttle return springs.
2 of the 3 I have, have been stretched and bent up by previous owners.
They are 3.5" long, but the best I can find are 2.75" and although the 2.75" ones stretch to fit, they are then too stiff to drive comfortably.
I've searched Burlens, Rimmers, SU Midel, eBay, etc, etc; without luck.
I'm looking for either good used or new. Can anyone point me in the right direction please?
Cheers,
Rob
mahony
Re: Sprint throttle return springs
#2 Post by mahony »
Sundowner
#3 Post by Sundowner »
Thanks for that, but they aren't the same.
The pic shows an original 3.5" Sprint spring (the only good one I have) and the shiny one that the vendors sell. I have a set of 3 of those and all they do is make the accelerator pedal really hard.
I could make up some sort of lengthening loop for them to hook into. A small key-ring perhaps. But I'd like the right springs if I can get them.
Once again, Thanks.
Cheers,
Rob
DSC06565 (1521 x 1140).jpg (295.72 KiB) Viewed 1344 times
PaulB
#4 Post by PaulB »
Try part number 153959 on Paddock website.
Sundowner
#5 Post by Sundowner »
Thanks for the part number Paul. Much appreciated.
Its the correct part and I've just ordered a set.
Again, my thanks.
Cheers,
Rob
Galileo
#6 Post by Galileo »
#7 Post by Toledo Man »
Rob, I think you've got the 1850 springs. They look similar to the new ones I bought recently.
Sundowner
#8 Post by Sundowner »
Toledo Man wrote:Rob, I think you've got the 1850 springs. They look similar to the new ones I bought recently.
Yes, I'm pretty sure you're right.
Why they're not marketed as being for the Sprint too, is strange.
I know my Sprint is unchanged from factory and the springs are original.
Anyway, its all sorted now, thanks to this forum and the people who frequent it.
Cheers,
Rob
James467
TDC Sprint Registrar
#9 Post by James467 »
I got these and they're fine.
http://www.rimmerbros.co.uk/Item--i-159463
If they weren't then believe me they would have known about it!! :lol:
