#616 Post by Carledo »
They are definitely steel, I had to do some welded mods on the Carledo to clear the exhaust and alter the gear lever position.
Mahesh
#617 Post by Mahesh »
Checked this morning, it is steel, just can't believe how light it is, and even with all the surface rust
not a single hole through.
#618 Post by Toledo Man »
How about Inca with stonechip underneath? You could make an inspection hatch for easy access to the clutch slave cylinder.
Flyfisherman
#619 Post by Flyfisherman »
Powder coated + access panel to bleed the clutch cylinder
Paul
Mahesh
#620 Post by Mahesh »
Nice, is that a foam or rubber seal ?
Flyfisherman
#621 Post by Flyfisherman »
Mahesh wrote:Nice, is that a foam or rubber seal ?
Neoprene
Paul
Mahesh
#622 Post by Mahesh »
While the tunnel is out might as well put a new speedo cable in, does anyone know how many teeth the pinion drive gear has? and it seems I don't have an angle drive
2016-05-30 19.55.35.jpg (104.2 KiB) Viewed 1478 times
#623 Post by xvivalve »
Sprints don't have an angle drive.
Mahesh
#624 Post by Mahesh »
Thanks, that's me looking at parts without double checking applicable models.
Mahesh
#625 Post by Mahesh »
An annoyance from day one, sorted
2016-05-31 20.45.42.jpg (116.2 KiB) Viewed 1429 times
Galileo
#626 Post by Galileo »
I just bought a GSD293 from RB for £11, and it fitted perfectly on the OD box. Previous owner had routed the old cable above the crossmember which seems to be too tight an angle, so I've found a clip that goes in the small hole in the end of the crossmember that holds the cable nicely and maintains a smooth radius. Nothing listed on the parts pages for that clip, but it is a very convenient hole and directly in line with the cable.
Pippin
#627 Post by Pippin »
Mahesh wrote:An annoyance from day one, sorted
So where did you get the green ring from for your cigarette lighter Mahesh?
Mahesh
#628 Post by Mahesh »
Ebay,
Steve recommend to look at old Ford's, this one is from a Capri.
3 mins in the ultrasonic, and it came out like new.
Mahesh
#629 Post by Mahesh »
Someone had to do it,
#630 Post by tony g »
You wont miss that in the dark 8)
