Hub to disc bolts
- SprintMWU773V
- TDC Staffs Area Organiser
Hub to disc bolts
Could someone enlighten me as to the correct bolt which secures the hub and disc? The parts book isn't very helpful and it'll be a pain to remove one. I'm compiling a list of missing bolts etc.
Re: Hub to disc bolts
Mark, my BT Cloud also includes the Standard-Triumph Hardware Catalogue which documents the various nuts, bolts, etc. You should be able to identify exactly what the bolt is.
Hope it helps.
Hope it helps.
- SprintMWU773V
I cannot get this to work unfortunately.
Neither can I.I cannot get this to work unfortunately.
Pretty sure theyre 3/8 unc but cant remember length sorry
- trackerjack
Definitely 3/8 UNC and must be 8.8 high tensile and the head would have to have three raised lines to denote a grade 5 bolt. I am almost certain that they are 1 1/2 inches long.
Here is one of the brake disc bolts from my 1850HL which is in pieces at the moment. The bolt is 3/8" UNC and 2" long.
- Disc Bolt.JPG (449.75 KiB) Viewed 963 times
That bolt is part number 157157. Mick Dolphin has them listed on his spreadsheet at £1.50 each. It isn't listed in my hardware catalogue and Rimmer Bros don't list it on their website either so I can't get any specs. The above photo is the best we have so far. The spring washer is WL209 (also listed under GHF333) which is a 3/8" spring washer.
- SprintMWU773V
It's annoying when people don't list the spec on the bolt page. I've never changed discs so didn't know they were UNC and I haven't bought new discs yet!
I hardly have any UNC in stock so will see what I can get at work, we have loads in stock so should be OK.
