" External Helicoil " ???
#1 Post by MIG Wielder »
Oh dear; I've done a silly. In Dremel-ling off the stuck tailshaft nut on my gearbox I've not been careful enough and I've put the grinding disc through the lower part of the thread. :-(
Now I'm familiar with Helicoils for reclaiming threaded holes in components , but is there a similar process for reclaiming external threads ?
Thanks,
Tony Burd
Re: " External Helicoil " ???
#2 Post by Tony Burd »
Build up with weld & recut thread?
dollyman
#3 Post by dollyman »
Hi Tony, looking at that i would just tidy the threads up with a thread file and just use a new nut.
Unless it looks a lot deeper in real life than on the photo?
Most of the "stress" will be on the splines anyway, if it was me? i would not worry.
Cheers, Tony.
Magenta Auto Sprint
#4 Post by Magenta Auto Sprint »
I agree, leave it as it is, if you try to weld it the heat will soften the hardened splines and may cause distortion.
Malcolm
#5 Post by tony g »
As above, clean up threads and make sure the nut goes on nicely while its out and rebuild :thumbsup:
#6 Post by MIG Wielder »
Thanks everyone for your comments. It looks like by the time the drive flange is on with its thick washer, the new nyloc has about 3 threads protuding. So an extra 2 threads worth of a 2nd thick washer should be O.K. and should take the beginning of the nuts start thread to about 1 turn in.
Panic over !
Should be O.K.
