OS steering rack mount (slant 4 engined models)
yorkshire_spam
#1 Post by yorkshire_spam »
Any top tips for getting the steering rack mount out of the RHS on an 1850?
Workshop manual just says withdraw bracket and u bolt. I can't see any way to get it clear of the oil pump?
Galileo
Re: OS steering rack mount (slant 4 engined models)
#2 Post by Galileo »
Only way I know is to undo the engine mounts and jack it up the 5cm or so needed to clear.
mahony
#3 Post by mahony »
It's been a while since I replaced a rack on a slant but I seem to remember jacking up the engine slightly with a block of wood on the sump to get clearence :D
yorkshire_spam
#4 Post by yorkshire_spam »
Oki doki guys, thanks.
Hollow laughter at #4 in the workshop manual.
I notice it doesn't mention "remove engine first"
:roll:
D16PJM
#5 Post by D16PJM »
i have just done my rack also 1850, i removed nut from OS engine mount and jack engine up enough to be able to get it out, i then noticed i needed a new UJ on the column so have done it twice now.
Pete
#6 Post by MIG Wielder »
When I did my 1850, the bracket came away in 2 parts. The long U-bolt ( upwards and then sideways ) and then the bracket bit. I thought it was something fitted to all early cars ??? My late Sprint had the 2 parts welded together though.
yorkshire_spam
#7 Post by yorkshire_spam »
The ones on Binny are definitely a single part bracket and U bolt welded together. I tried separating them... very definitely 1 part.
Galileo
#8 Post by Galileo »
yorkshire_spam wrote: Sun Jun 17, 2018 1:36 pm Oki doki guys, thanks.
:roll:
Well there, now you see Haynes and his much maligned manual says
"Support the right-hand side of the engine on a jack and remove the engine mounting. Raise the engine a little with the jack to enable the procedure in paragraph 5 to be carried out."
Pays to read both! :)
yorkshire_spam
#9 Post by yorkshire_spam »
Galileo wrote: Sun Jun 17, 2018 9:07 pm Well there, now you see Haynes and his much maligned manual says
I can't believe I'm saying this...... "I might have to get a Haynes manual"
Galileo
#10 Post by Galileo »
yorkshire_spam wrote: Sun Jun 17, 2018 9:58 pm I can't believe I'm saying this...... "I might have to get a Haynes manual"
Steady on now, open talk of such a nature could get this thread moved to the TDC dark net. :wink: :lol:
geeksteve
#11 Post by geeksteve »
Remember to open the bonnet before jacking the engine.. ;)
yorkshire_spam
#12 Post by yorkshire_spam »
Galileo wrote: Sun Jun 17, 2018 10:38 pm
It's here!
A bit battered and used, but what do you expect for £1+postage? :)
Galileo
#13 Post by Galileo »
Ok, I guess it's my turn then, so, my names Rafael and I own a Haynes manual! :lol:
(rogue Autodata one got in the pack!)
