Overdrive gear knob removal
HQentity
#1 Post by HQentity »
Hiya!
Bit of a beginner question here, but I'm trying to get the gearstick gaiter around the gear knob, but can't work out how to remove the (new!!) overdrive gear knob to get the gaiter past it. Any advice please? :)
Many thanks!
HQentity (Kyle)
matienzo
Re: Overdrive gear knob removal
#2 Post by matienzo »
Plastic top of knob simply prises off. Lift up carefully and disconnect overdrive wires.
Remove knob by undoing the lock nut on the bottom. Look carefully and you will see the flats.
Steve and Nic
Larger garage needed
cliftyhanger
#3 Post by cliftyhanger »
Yes, loosen the locknut at the bottom.
Top off with a thin screwdriver or similar.
Wires off.
Then there is a funny ring nut inside that has a pair of slots. I use a screwdriver in a slot to rotate the ring, usually they move easily.
HQentity
#4 Post by HQentity »
Oh, I was so close! I got as far as the ring nut, but I didn’t trust myself so I stopped! :lol: thanks!
HQentity (Kyle)
cleverusername
#5 Post by cleverusername »
HQentity wrote: Sat Mar 02, 2019 8:39 pm Oh, I was so close! I got as far as the ring nut, but I didn’t trust myself so I stopped! :lol: thanks!
One note of caution, the ring nut can sometimes be rusted on and a b**ger to remove. Hopefully that isn't the case in your case.
I have wondered whether there is a special tool? Rather than my method of turning it with a flat screwdriver?
I had to drill the nut off the one on my Sprint gearstick to shift it.
Matt Cotton
#6 Post by Matt Cotton »
Funny, I have just come in from the garage having struggled to do exactly the same job.
The little ring nut was very tight to get off and even when it was off, the knob still required a really good pull to remove it.
Matt Cotton
1980 1500HL - OPD
1976 Sprint - SWU
#7 Post by Carledo »
I use circlip pliers on the ring nut!
Robert 352
#8 Post by Robert 352 »
I think I may have covered this before and posted a photo of the tool which I made out of a piece of tube. It was a piece of conduit pipe which I salvaged out of an old house in which the old electrical wiring was run.
I filed the end of the tube to form the two little projections you can see and then slid it down over the switch connectors. I use it to both unscrew and screw up the collar.
The other thing which I do is to work the wire which exits the gearstick somewhere below the gaiter with an action a bit like milking a cow. Work the wire up so that you can disengage the connectors from the back of the switch and then when you are replacing the switch use the same action to pull the wire down the gearstick and allow the plastic top to be pulled down until it almost clips into place. By doing so you are not bunching up the wire beneath the switch itself.
This tool and a dozen or more others sit in my drawer marked “Triumphant Tools”. We need to have a triumph now and again.
Robert
20170407-6184Ptw Gearlever collar spanner.jpg (97.27 KiB) Viewed 2253 times
