Bit of a beginner question here, but I'm trying to get the gearstick gaiter around the gear knob, but can't work out how to remove the (new!!) overdrive gear knob to get the gaiter past it. Any advice please?
Plastic top of knob simply prises off. Lift up carefully and disconnect overdrive wires.
Remove knob by undoing the lock nut on the bottom. Look carefully and you will see the flats.
Steve and Nic
Larger garage needed
Yes, loosen the locknut at the bottom.
Top off with a thin screwdriver or similar.
Wires off.
Then there is a funny ring nut inside that has a pair of slots. I use a screwdriver in a slot to rotate the ring, usually they move easily.
I think I may have covered this before and posted a photo of the tool which I made out of a piece of tube. It was a piece of conduit pipe which I salvaged out of an old house in which the old electrical wiring was run.
I filed the end of the tube to form the two little projections you can see and then slid it down over the switch connectors. I use it to both unscrew and screw up the collar.
The other thing which I do is to work the wire which exits the gearstick somewhere below the gaiter with an action a bit like milking a cow. Work the wire up so that you can disengage the connectors from the back of the switch and then when you are replacing the switch use the same action to pull the wire down the gearstick and allow the plastic top to be pulled down until it almost clips into place. By doing so you are not bunching up the wire beneath the switch itself.
This tool and a dozen or more others sit in my drawer marked “Triumphant Tools”. We need to have a triumph now and again.
Robert
20170407-6184Ptw Gearlever collar spanner.jpg (97.27 KiB) Viewed 2247 times
