Door check strap pins
GrahamFountain
#1 Post by GrahamFountain »
It seems that both the front door check strap pins have gone walkies while the paint was drying.
Anybody any idea where I might get a pair. Like, are they the same as 2000's?
new to this
Re: Door check strap pins
#2 Post by new to this »
Sorry don't know size but you can buy clevis pins on eBay
dollyman
#3 Post by dollyman »
As a temp fix, a 7/16th nyloc nut and bolt will work :D
roadster
#4 Post by roadster »
Yes I have just replaced some rust old bolts with these
https://www.ebay.co.uk/itm/323714173870 ... 3714173870
1/4 dia X 5/8 long seems about right although the perfectionist might drill out elongated holes to a slightly bigger size.
Bumpa
#5 Post by Bumpa »
dollyman wrote: Sat Mar 09, 2019 10:37 pm As a temp fix, a 7/16th nyloc nut and bolt will work :D
Yep. That's what I did!
GrahamFountain
#6 Post by GrahamFountain »
The bolt nyloc and washers sounds good as a temp fix, but does anybody know if this https://rimmerbros.com/Item--i-613622FK will fit the dolomite's check straps?
dollyman
#7 Post by dollyman »
Those are ones Graham :D I have to confess i left the nut and bolt in mine as they were stainless :wink:
GrahamFountain
#8 Post by GrahamFountain »
Well I've ordered the nuts bolts and washers in stainless, as part of getting the bits to mount the front headlamp panels. So I'll fit those for now and see if I feel like getting the clevis pins later.
Thanks all.
#9 Post by Carledo »
Original factory equipment was a rivet, normally completely or partially destroyed on removal!
Personally, i'm a fan of the 1/4" clevis pin and R clip (as used on brake pad pins) A neat and easy to remove solution!
James467
TDC Sprint Registrar
#10 Post by James467 »
