Door check strap pins
- GrahamFountain
It seems that both the front door check strap pins have gone walkies while the paint was drying.
Anybody any idea where I might get a pair. Like, are they the same as 2000's?
Re: Door check strap pins
Sorry don't know size but you can buy clevis pins on eBay
- TDC Cheshire Area Organiser
As a temp fix, a 7/16th nyloc nut and bolt will work
NOW A CLUB MEMBER 2017057
Yes I have just replaced some rust old bolts with these
https://www.ebay.co.uk/itm/323714173870 ... 3714173870
1/4 dia X 5/8 long seems about right although the perfectionist might drill out elongated holes to a slightly bigger size.
Yep. That's what I did!
- GrahamFountain
The bolt nyloc and washers sounds good as a temp fix, but does anybody know if this https://rimmerbros.com/Item--i-613622FK will fit the dolomite's check straps?
Those are ones Graham
I have to confess i left the nut and bolt in mine as they were stainless
- GrahamFountain
Well I've ordered the nuts bolts and washers in stainless, as part of getting the bits to mount the front headlamp panels. So I'll fit those for now and see if I feel like getting the clevis pins later.
Thanks all.
Thanks all.
Original factory equipment was a rivet, normally completely or partially destroyed on removal!
Personally, i'm a fan of the 1/4" clevis pin and R clip (as used on brake pad pins) A neat and easy to remove solution!
