Heat sheild
new to this
Heat sheild
#1 Post by new to this »
How many heat sheilds does the Sprint have ? i know theres one for the starter motor, think it fits on the exhaust pipe near the starter,any more
Re: Heat sheild
#2 Post by xvivalve »
Three.
The starter motor heat shield clips to the solenoid body.
There is a bulkhead heat shield pop riveted to the bulkhead where the down pipe passes close.
The automatic also has a heat shield riveted to the transmission tunnel to protect the inhibitor switch from exhaust heat, but that one isn’t particularly effective!
new to this
Re: Heat sheild
#3 Post by new to this »
xvivalve wrote: Wed Feb 03, 2021 6:56 am Three.
Alun
Thanks,thats helpful
Re: Heat sheild
#4 Post by xvivalve »
This is the bulkhead one:
Tony Burd
Re: Heat sheild
#5 Post by Tony Burd »
There is one on the manual transmission tunnel as well.
new to this
Re: Heat sheild
#6 Post by new to this »
xvivalve wrote: Thu Feb 04, 2021 7:42 am This is the bulkhead one:
Alun
Would you have a photo of the heat sheild for the starter motor
new to this
Re: Heat sheild
#7 Post by new to this »
Tony Burd wrote: Thu Feb 04, 2021 3:32 pm There is one on the manual transmission tunnel as well.
I see thats pop riveted on as well thanks
Re: Heat sheild
#8 Post by xvivalve »
new to this
Re: Heat sheild
#9 Post by new to this »
xvivalve wrote: Thu Feb 04, 2021 8:32 pm Image
Alun
Thanks dosent look as big as i expected
Re: Heat sheild
#10 Post by Carledo »
new to this wrote: Thu Feb 04, 2021 10:43 pm
Alun
Thanks, doesn't look as big as I expected
It only really protects the solenoid and wiring terminals. Plus it's nearly always missing anyway!
marshman
Re: Heat sheild
#11 Post by marshman »
As Steve says it just clips on top of the starter solenoid - circled in red in the picture below:
Roger
1971 Stag Auto White
Robert 352
Re: Heat sheild
#12 Post by Robert 352 »
You have asked for a photo of the shield which sits on the starter motor.
Here is a photo of a Sprint engine showing that heat shield.
Robert
20210209-1994Ptf HU 5089 Starter motor heat shield.jpg (263.16 KiB) Viewed 1275 times
GrahamFountain
Re: Heat sheild
#13 Post by GrahamFountain »
Anybody got distentions? Especially for the Terry clip that holds it on (obviously not so well if they're mostly missing).
Magenta Auto Sprint
Re: Heat sheild
#14 Post by Magenta Auto Sprint »
does anyone have a sketch of the heat shield for the auto box please?
Both my 1850 and sprint could do with one, all I have left are bits held on by the bolts.
thanks
Malcolm
RSi
Re: Heat sheild
#15 Post by RSi »
There's also a brake pipe shield.
Club Membership No: 2017092
