Mudsheilds
GrahamFountain
Mudsheilds
#1 Post by GrahamFountain »
Anybody any idea where I might get a right hand upper mudsheild, XKC 1308?
Richard the old one
Re: Mudsheilds
#2 Post by Richard the old one »
I think to be certain which one you need it would be better to state if it is the nearside or offside of the car as right and left depends on which way you are looking at the car
Re: Mudsheilds
#3 Post by Carledo »
Richard the old one wrote: Sat May 04, 2019 1:37 pm I think to be certain which one you need it would be better to state if it is the nearside or offside of the car as right and left depends on which way you are looking at the car
Nearside or offside depends on whether it's a RHD or LHD car, something Brits often forget! RHS or LHS has no such inconsistency as it's always stated as seen from the drivers seat looking forward and that doesn't vary!
TrustNo1
Re: Mudsheilds
#4 Post by TrustNo1 »
Left/ right is and has always been as viewed from the drivers seat looking in direction of travel.
Re: Mudsheilds
#5 Post by xvivalve »
I’ve recently obtained a box full of various second hand plastic mud shields...
GrahamFountain
Re: Mudsheilds
#6 Post by GrahamFountain »
xvivalve wrote: Sun May 05, 2019 9:34 am I’ve recently obtained a box full of various second hand plastic mud shields...
What price inc P&P for a pair of the rear top ones - I have the left one but it's got a cut where the old wing was cut off.
Last edited by GrahamFountain on Mon May 06, 2019 8:27 pm, edited 1 time in total.
GTS290N
Re: Mudsheilds
#7 Post by GTS290N »
TrustNo1 wrote: Sat May 04, 2019 6:47 pm Left/ right is and has always been as viewed from the drivers seat looking in direction of travel.
I've been waiting until this thread ran it's course - [edit] delete Alun insert Carledo [end edit] description is accurate, but from your's - if you are reversing...........
Definition of pedantry..
TrustNo1
Re: Mudsheilds
#8 Post by TrustNo1 »
GTS290N wrote: Mon May 06, 2019 6:57 pm
I've been waiting until this thread ran it's course - Alun's description is accurate, but from your's - if you are reversing...........
'I’ve recently obtained a box full of various second hand plastic mud shields...' is more a statement than a description :bonk:
GrahamFountain
Re: Mudsheilds
#9 Post by GrahamFountain »
Came to fit the upper rear mudshields Alun sent me, and found out why there was only one with the car: there are no fixing holes on the LH side of the car.
Worse, there's no chance I'll get my drill in there to make some.
Doesn't look like the hot glue gun's an option either. If only I'd know about it when the wing was off.
By LH I mean the drivers side.
But that's because it's a Left Hand Drive car.
According to an O.U. programme I watched many moons ago, left and right are a bit hard to differentiate without a preexisting shared reference.
But I only watched it cos there were nowt else on - I weren't one of them O.U. Pretty Things Bowie sung about.
Re: Mudsheilds
#10 Post by xvivalve »
Would a right angle drill attachment get sufficiently close?
GrahamFountain
Re: Mudsheilds
#11 Post by GrahamFountain »
I would think so. I'm ebaying right now.
GrahamFountain
Re: Mudsheilds
#12 Post by GrahamFountain »
I can drill the front hole with an angled drive, but the back one's too tight.
I think I can bolt a poundlands best, right angle bracket to the back of the shield, and get to the inner wing side of underneath the strengthener to screw a stainless no 8 self tapper in there. Maybe I can do that for both ends, and I don't need the right angle drive. If I use a countersunk bolt betwixt shield and bracket, that'll move the shield right by the thickness of the bracket alone. About 2mm. I think that'll be okay.
SprintMWU773V
TDC Staffs Area Organiser
Re: Mudsheilds
#13 Post by SprintMWU773V »
Or use Tigerseal
GrahamFountain
Re: Mudsheilds
#14 Post by GrahamFountain »
Well I finally got the damned thing on: when I came to fit the steel plates at the back of the wheel arch, they needed a bit of work first. I did it with the right angle brackets, though I ended up using No. 14 self tappers with 10mm af heads.
