Electric water pump
Electric water pump
How do most people mount a electric water pump / do you have to trim the subframe
Re: Electric water pump
You don't "mount" it as such, you just let it hang off the hoses! (it's not at all heavy) I have one so fitted on the drive, i'll take a pic or two tomorrow.
Okay........
Although compact in size, it is heavy, so a Stewart pump has a mounting flangenew to this wrote: ↑Sat Aug 01, 2020 8:24 pm How do most people mount a electric water pump / do you have to trim the subframe
for attachment on to a bracket.
Said bracket needs to be attached to the engine block.
You do not have to modify the body or subframe.
(There may be a bracket available off the shelf for a slant four but I haven't looked
because I think it is easy enough to make one (and I have plenty of suitable s/h steel.)
Ian
Ok so it depends whose pump you use, the Davis Craig pump is quite happy unsupported!
PS sorry, forgot pix had a lot on my mind with RBRR being postponed till next year as of today!
- gmsclassics
As Steve said, Davies Craig pump doesn't need any further support than the hoses. Pic below is from my race car (which got driven very hard) and this is the bigger EWP115 model. If you want to see how hard it was driven, search YouTube for 'Dolomite Sprint No 20'.
Geoff
Geoff
- photo 4.JPG (120.19 KiB) Viewed 979 times
Hi can any one tell me the water flow direction for the Sprint
thanks Dave
thanks Dave
Yes.....
From the bottom of the radiator to the water pump.new to this wrote: ↑Mon Aug 03, 2020 11:00 pm Hi can any one tell me the water flow direction for the Sprint
thanks Dave
Re: Yes.....
Iansprint95m wrote: ↑Tue Aug 04, 2020 11:35 amFrom the bottom of the radiator to the water pump.new to this wrote: ↑Mon Aug 03, 2020 11:00 pm Hi can any one tell me the water flow direction for the Sprint
thanks Dave
I need a bit more information than that
Im going to try a new set up Ford Essex belt driven pump , i know its been done on the Stag
Re: Yes.....
No it goes the other way, from stat housing, through manifold then to heater and back to water pump housing. If you fit an electric pump, the heater return needs to be tee'd into the bottom hose between the pump and the rad or the heater won't work. You can see this return pipe in the pic of Geoff's race car.new to this wrote: ↑Tue Aug 04, 2020 4:28 pmIansprint95m wrote: ↑Tue Aug 04, 2020 11:35 amFrom the bottom of the radiator to the water pump.new to this wrote: ↑Mon Aug 03, 2020 11:00 pm Hi can any one tell me the water flow direction for the Sprint
thanks Dave
I need a bit more information than that![]()
am i right in thinking , comes out of water pump cover to heater,round heater and back through thermostat back in radiator to complete the cycle
Hmm.....
I'll be interested to see how you get on with this Dave.new to this wrote: ↑Tue Aug 04, 2020 4:28 pm Im going to try a new set up Ford Essex belt driven pump , i know its been done on the Stag[/color]
The person who developed the Stag conversion posts on the Sideways forum,
from pictures he has posted there I concluded that there isn't enough room on a Sprint
to get the pump sufficiently low to work efficiently?
On the heater supply question, I stick by my previous answer of having the feed from the cylinder head.
This gives more heat and an easier plumbing solution for an EFI set up.
