Electric water pump
new to this
Electric water pump
#1 Post by new to this »
How do most people mount a electric water pump / do you have to trim the subframe
Re: Electric water pump
#2 Post by Carledo »
You don't "mount" it as such, you just let it hang off the hoses! (it's not at all heavy) I have one so fitted on the drive, i'll take a pic or two tomorrow.
Okay........
#3 Post by sprint95m »
new to this wrote: Sat Aug 01, 2020 8:24 pm How do most people mount a electric water pump / do you have to trim the subframe
Although compact in size, it is heavy, so a Stewart pump has a mounting flange
for attachment on to a bracket.
Said bracket needs to be attached to the engine block.
You do not have to modify the body or subframe.
(There may be a bracket available off the shelf for a slant four but I haven't looked
because I think it is easy enough to make one (and I have plenty of suitable s/h steel.)
Ian
#4 Post by Carledo »
Ok so it depends whose pump you use, the Davis Craig pump is quite happy unsupported!
PS sorry, forgot pix had a lot on my mind with RBRR being postponed till next year as of today!
gmsclassics
#5 Post by gmsclassics »
As Steve said, Davies Craig pump doesn't need any further support than the hoses. Pic below is from my race car (which got driven very hard) and this is the bigger EWP115 model. If you want to see how hard it was driven, search YouTube for 'Dolomite Sprint No 20'.
Geoff
photo 4.JPG (120.19 KiB) Viewed 974 times
new to this
#6 Post by new to this »
Hi can any one tell me the water flow direction for the Sprint
thanks Dave
Yes.....
#7 Post by sprint95m »
new to this wrote: Mon Aug 03, 2020 11:00 pm Hi can any one tell me the water flow direction for the Sprint
thanks Dave
From the bottom of the radiator to the water pump.
new to this
Re: Yes.....
#8 Post by new to this »
sprint95m wrote: Tue Aug 04, 2020 11:35 am
thanks Dave
Ian
I need a bit more information than that :D :D am i right in thinking , comes out of water pump cover to heater,round heater and back through thermostat back in radiator to complete the cycle
Im going to try a new set up Ford Essex belt driven pump , i know its been done on the Stag
Re: Yes.....
#9 Post by Carledo »
new to this wrote: Tue Aug 04, 2020 4:28 pm
thanks Dave
Ian
No it goes the other way, from stat housing, through manifold then to heater and back to water pump housing. If you fit an electric pump, the heater return needs to be tee'd into the bottom hose between the pump and the rad or the heater won't work. You can see this return pipe in the pic of Geoff's race car.
Hmm.....
#10 Post by sprint95m »
new to this wrote: Tue Aug 04, 2020 4:28 pm Im going to try a new set up Ford Essex belt driven pump , i know its been done on the Stag[/color]
I'll be interested to see how you get on with this Dave.
The person who developed the Stag conversion posts on the Sideways forum,
from pictures he has posted there I concluded that there isn't enough room on a Sprint
to get the pump sufficiently low to work efficiently?
On the heater supply question, I stick by my previous answer of having the feed from the cylinder head.
This gives more heat and an easier plumbing solution for an EFI set up.
